  • Guests: 37
Sanchez (36)
Knarvel (13)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
Mounting a PC board without mounting holes?
waffle
Thu May 21 2009, 01:39AM Print
waffle Registered Member #642 Joined: Fri Apr 13 2007, 10:19PM
Hi everyone. I need some help figuring out how to mount a PC that has no mounting holes. The board is for an under-cupboard LED lighting system. Each individual board is 12" long and .6" wide. The way the board has been designed doesn't allow for mounting holes(in order to keep things as thin as possible). If anyone has experience mounting a board like this, I would greatly appreciate the help.
I was thinking that it could be mounted in some sort of channel that would allow it to be slid into. I have never seen channel like this, nor do I know where I would find this channel, but here's a picture of what it would ideally look like. The board's width can be expanded to a more common size within reasonable constraints in order to fit this type of channel if needed.
Here's a side view of the channel.
1
rp181
Thu May 21 2009, 02:03AM
Do you know someone that machines stuff? If so, Ask them to "dado" a block of wood to the PCB thickness with a table saw. Like this, you just set the blade low, and run the wood through several times.
Dr. Slack
Thu May 21 2009, 06:55AM
Is it a commercial system, if so, do you know what the manufacturer intended to be used? Usually that will be the neatest and easiest option, though not necessarily the cheapest.
If you've made it, then "keeping it as thin as possible" is a classic example of going for the wrong optimum, it needed to be not "thin as possible" but "easy to fit" as well.
You could try visiting your local DIY, and looking for plastic channel. What's available in them depends on your locality. I dont know where you live, but in the UK wiring regulations say that fixed surface cables must be enclosed in conduit or trunking. This means that there are several profiles of mini PVC trunking available, including 16mm and 20mm wide IIRC, that might do the trick if used without the lid.
How about if you removed every 2nd white LED for example and drilled through the board to make a fixing hole, wiring damaged tracks across if needed?
Thu May 21 2009, 09:57AM
No More Nails? Double sided sticky foam?
lpfthings
Fri May 22 2009, 10:32AM
lpfthings Registered Member #1361 Joined: Thu Feb 28 2008, 10:57AM
Ive seen this stuff around, looks sorta like what you were talking about ..
Fri May 22 2009, 10:19PM
Dennis Rogers Registered Member #1837 Joined: Tue Dec 02 2008, 02:20PM
Another idea might be to get nylon standoff's and epoxy them onto the board.
Look here, Link2
The one on the top left could be glued to the board and snap into a small hole you drill into whatever you will mount the board to.
Sun May 24 2009, 07:14AM
Pcb guide rails for 19" racks could be useful?
e.g. Link2
