  • Guests: 139
seveerz (69)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
Disassembling an CRT monitor
lhl_henrylui
Wed May 20 2009, 10:22AM Print
lhl_henrylui Registered Member #1498 Joined: Thu May 22 2008, 07:08AM
I've just got this CRT monitor and I'm going to open it.
As I'm a amateur,please tell me what safety paperation I should do and how can I safely disassemble it.
I know I have to discharge the CRT by connecting the suction cap and the ground.But I'm still afraid if there's any other dangers.Also, I want to know whether I should discharge the capacitors in the power supply circuit.Please tell me anything that is important.
1242814935 1498 FT0 Whole
1242814935 1498 FT0 Front
big5824
Wed May 20 2009, 10:57AM
leave it for at least a few hours after unplugging it, then id short out every capacitor you can to avoid shocks, and yes the tube can hold a very high charge so that needs shorting too.
GeordieBoy
Wed May 20 2009, 11:21AM
Along with the stored-charge hazard, there is also a risk of implosion from the CRT that contains a vacuum. Some safety tips are here:
If you aren't confident about what you are doing, then put the lid back on, and just dispose of the appliance safely smile
-Richie
Dr. Slack
Wed May 20 2009, 02:51PM
If you do nothing else in the way of safety, then wear a pair of safety glasses any time you are in the back of the monitor. You are unlikely to die from shocks from the caps in the TV, but a discharge, whether it causes you a shock, or whether it just makes an unexpected noise, could cause a reflex flinch that has you do something upsetting; like maybe drop the heavy tool you are holding on a weak bit of the tube. The emergency room has much better outcomes with glass in skin than with glass in eyes. Wearing them could make the difference between a story to tell your mates in the bar, and something life-changing.
Wed May 20 2009, 05:14PM
Yes, the CRT has enough of a charge when fully charged to really kick your butt. It would not likely kill you if you are healthy (If you have a defibrillator it is a bad idea, in other words) but why take a chance? Also some moniter flybacks have an internal capacitor that is good for apparently a few nf. That would suck!
Most of the time mine would only hold a charge of a few hundred voltage, it mostly bled off very quickly. The large electrolytics on the board should be shorted with a wire with good insulation, or just an old cruddy screw driver. I have had a few TV's and moniters that would still make quite a noise when shorted after i took them apart. Never been shocked with them though.
Wavetuner
Fri Jun 19 2009, 11:20AM
Wavetuner Registered Member #1500 Joined: Sat May 24 2008, 04:38PM
A little late on this one. The CRT is disigned to hold a charge and usually will for a long time. It is in essence used as a HV capacitor. To safely discharge it first thing to do, take a clip lead and strongly connect to a ground point, connect the other end to a long shank screw driver and hold it by the end of the plastic handle push the blade into the anode cap to make contact with the anode clip. SNAP. You would be stuned by that at a minimum.
We use to (With safety googles) drive a screw driver in the rear of the electron gun to equalise the vacumn. Do NOT break the neck as it can implode in and could richochete outward like a spear or so I have heard. Care must be taken if removing the yoke for this reason.
Fri Jun 19 2009, 11:29AM
:-D
I have disassembled a dozen of TVs and Monitors and I just always tore the suction cup off the CRT while holding the insulated part. Never got a shock. Also the implosion of newer CRT's is nothing dramatic, I think they are designed to self-contain the damage without sending any glass "shrapnels". There are a lot of videos on YT of people throwing dead CRTs from a great height and they just make a thud.
However I don't encourage anyone to do what I did, always be on the safe side, just think that TV/monitor disassembly is nothing you would need safety goggles and electrician's gloves for cheesey
KLH
Fri Jun 19 2009, 05:57PM
When you discharge any high voltage storage device (and there are a lot in a CRT monitor), either wear a welding eye shield, powerful sunglasses, or just look away from the spark in order to avoid the risk of eye damage from UV radiation given off by the arc. Even if there isn't much radiation, it sucks to see big bright spots for hours.
Backyard Skunkworks
Fri Jun 19 2009, 07:01PM
Arcstarter wrote ...
Its actually not very hard to make a nice dischange probe that will save your screwdrivers from getting blown up.
I generally use a piece of coathanger wire with a handle made out of several layers of polyethylene tubing wrapped in electrical tape.
A probe like that will hold up for a fairly long time and is a lot easier to squeeze into tight places than a screwdriver.
And as always, wear gloves and eye protection!
thedatastream
Fri Jun 19 2009, 07:53PM
We used to do TVs at work years ago. We always removed the "poppie" EHT from the top of the tube by inserting a grounded screwdriver in underneath the poppie cover to discharge the capacitance before removing it.
If you are intending to dispose of the tube, you need to re-pressurise it first. Remove the tubebase board (opposite end of the tube to the screen) by carefully pulling. Look down the very end tip and you should see a glass nipple. Wearing safety glasses, use a screwdriver and a hammer to gently tap this until it cracks - you will hear a hissing as the vacuum is filled with air. Leave until it stops hissing and the tube should be much safer to dispose of (it won't work though!)
