  • Guests: 43
Sanchez (36)
Knarvel (13)
10/16 Sanchez (36)
10/16 Knarvel (13)
driving a motor with op amp
polop
Mon May 18 2009, 04:41PM Print
polop Registered Member #1537 Joined: Thu Jun 12 2008, 06:44PM
is it possible to drive a motor using a high power opamp, without all the shrapnel they say to use in the data sheet. ie just a voltage follower connected to a motor with a protection diode.
ps, the opamp i am proposing is this one Link2
big5824
Mon May 18 2009, 05:48PM
well without telling us what rating the motor is we cant do much....but that opamp can output 3A tops, so if your motor draws less than that then i dont see why not.
However youd be much better off using a MOSFET as the driver, and then just use a low power cheaper op amp to control it.
Mon May 18 2009, 05:51PM
If you look at the data sheet you'll see there's an internal diode
from the output pin to the +Vs pin,
so if you're going to operate in a unipolar mode (one direction only, Motor+ to +Vs)
the internal diode should suffice.
Personally I'd add 2 diodes as in Figure 1 of the data sheet
whether unipolar or bipolar (Fwd/Rev).
Internal SOA and thermal protection should cover most other fault conditions.
polop
Mon May 18 2009, 06:59PM
h the motor specs are quite low, i was thinking two of the small flat sided motors less than an amp i total i guess. i will be driving it bipolar, so that when the output of the opamp is positive the motor turns one way and when it is negative it turns the other way.
Tue May 19 2009, 09:38AM
When I've needed to do this in the past, I made an H-bridge with four power BJTs, driven by two regular small-signal op-amps, plus some booster transistors, as the op-amps couldn't give enough current to drive power transistors directly.
For an inductive load, two clamp diodes per output are certainly a good idea. I was driving peltiers, not motors, so I didn't need them.
Tue May 19 2009, 06:53PM
If battery powered you may want to consider a full H-bridge package/ic.
For the cost of postage I can send a couple of LMD18245T packages,
though they're meant for 12-50 V supply.
The inductance and inertia of electric motors makes them ideal candidates for PWM controllers.
polop
Wed May 20 2009, 01:43PM
thanks allot for the offer, though in the design i am wanting to make there will be no microprocessor, it is all analogue, i amy go with a design similar to the motor controll section of this schematic. Link2 and for clarity the project as a whole will be similar to this schematic with some modifications.
Bjørn
Wed May 20 2009, 03:50PM
PWM has nothing to with microprocessors, why not have a look at the specificatiuons and datasheet? Link2
polop
Wed May 20 2009, 05:38PM
as far as i can see the input for that device is a 4bit binary that is internally converted to analogue to make the pwm signal, as my project does not have a microprocessor ii cannot produce the binary number necessary to drive the chip, hence any pwm ic i use will have to have a voltage controlled driving circuitry.
p.s. i did look at the data sheet before posting previously.
MinorityCarrier
Wed May 20 2009, 07:01PM
Just buy a 10-position 4-bit BCD switch or a 16-position true binary switch, and use these to control the 4-bit data line. No uC or any other digital chips required.
