  • Guests: 37
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
IR photodetector and emitter pair.
Sat May 16 2009, 08:28PM Print
Hello there.
I recently bought a phototransistor/IR emitter LED pair, for a small project. Basically, i just need the signal to be interrupted as a spinning disk reached a certain point.
I will not post pictures rigght now, if you guys need one or do not know what is wrong without pictures, taking them is not problem.
Alright. Basically, i have two small circuit boards, with the LED's soldered onto them. To hold the two circuit boards away from each other, to give the LED's about 1/4 inch clearance from each other (to allow space for an obstruction to interrupter the signal) i used a screw with nuts to be able to adjust the clearance.
That is the schematic. I have the collector connected to V+ and the emitter is the output, with a 10kohm resistor connecting it to ground. Remember, this is two separate LED's with space in between them, to allow for an obstruction.
EDIT: I do have a 270 ohm resistor in series with the IR emitter. I forgot to add it on the schematic.
The problem is that no matter if there is an obstruction, the output of the phototransistor is always about 4.8 volts, which is about .3 volt drop from the source. Nothing heats at all. The output had not load other than a volt meter. When it works, the output will be on the base of a transistor for the
switching.
When i had the emitter connected to ground, with the collector being the output with a 10kohm resistor to V+, it worked just fine. It is a very simple circuit, so i do not know how i could have possibly messed anything up... I just need a positive output to give a signal to the base of an NPN transistor.
Thanks in advance.
Hon1nbo
Sat May 16 2009, 09:10PM
from what I can tell,
the connection of the transistor via the 10k ohm resistor to ground essentially acts as a path for the V+ to go to your output, assuming your output also goes to ground...
then again, if that were the case it should be less than 4.8V on the output? try using a diode instead of a resistor to prevent V+ from flowing in the wrong direction... (e.g. in your schematic have it face to the left)
Sat May 16 2009, 11:05PM
DaJJHman wrote ...
Gah, i am so stupid D':.
Lol, apparently i thought i used such high resistance the voltage drop would be MUCH more. Thanks, man.
Update: Killed it. Apparently the base of a darlington pulls more than 50ma at 5 volts.
MinorityCarrier
Sun May 17 2009, 08:56PM
It's not clear where you have your common return, but based on this schematic I think you will either blow the LED or the phototransistor.
Typically a current limit resistor is between the V+ and the LED anode, LED cathode is to common.
If you want an Active High output, the phototransistor collector is to V+, and a resistor is tied from the emitter to common. Signal is from emitter.
If you want an Active Low, then emitter is tied to common, and a resistor is inserted between V+ and collector. Signal is then from the collector.
