  • Guests: 80
Elliott (35)
Gratitude (40)
Swraka (37)
12/27 Elliott (35)
12/27 Gratitude (40)
12/27 Swraka (37)
Netzpfuschers DRSSTC [edit: video]
Netzpfuscher
Fri May 15 2009, 04:49PM Print
Netzpfuscher Registered Member #1131 Joined: Mon Nov 19 2007, 01:36PM
Im working a couple of months now on my new DRSSTC with my own IGBT driver with desat. detection. The DRSSTC Controler is nearly steve wards design with little modification for fault detection from the igbt drive and a second fault-pin for future use. This is my photostory.
Technical Data:
-Mitsubishi IGBT 1200V 400A
-3ph Semikron bridge rectifier
-optical driver with desat. detection and fault output (+30 -10V gate drive)
-smps for gate drive and logic
-dead-time generator for igbt drive and desat. detection
testing the smps and driver
http://kerrinnes.de/igbt/new/003.jpg
http://kerrinnes.de/igbt/new/002.jpg
http://kerrinnes.de/igbt/new/001.jpg
dead-time generator
http://kerrinnes.de/igbt/new/005.jpg
http://kerrinnes.de/igbt/new/006.jpg
first test with coil
http://kerrinnes.de/igbt/new/007.jpg
http://kerrinnes.de/igbt/new/008.jpg
400mm² output terminals
http://kerrinnes.de/igbt/fin1.jpg
http://kerrinnes.de/igbt/fin2.jpg
finished setup
http://kerrinnes.de/igbt/ins2.jpg
http://kerrinnes.de/igbt/ins3.jpg
http://kerrinnes.de/igbt/ins1.jpg
A little video from my coil in action, bus voltage is about ~300V. I tuned the primary a little bit lower than the secondary. Streamers are about 1,2-1,5m... :)
http://www.youtube.com/watch?v=5IJJb-baabo
Fri May 15 2009, 05:54PM
Your photos are all far over the 400 pixel width limit, please resize them or they will be deleted.
twist2b
Fri May 15 2009, 06:11PM
twist2b Registered Member #2086 Joined: Tue Apr 21 2009, 02:33AM
Thats pretty!!!!
Where did you get the boards? Did you make them?
