  • Guests: 62
Lyonel Baum (77)
Mattc1886 (17)
01/09 RickR (18)
01/09 TheBoozer (58)
01/09 invader (50)
160J Semiauto Coilgun Pistol
Camel
Mon May 11 2009, 12:33PM Print
Camel Registered Member #1694 Joined: Sat Sept 13 2008, 09:13AM
Hi,
I am working on a semiautomatic coilgun pistol. The goal for this project is to develop a moderately powerful pistol with a good rate of fire.
Specs
- 1 Injector coil driven by 2x 100uF 400V caps.
- 2 coils, both connected to 990uF 400V capacitor banks.
- Optically triggered V-switching arrangement.
- 20x AA NiMH cells
- ZVS flyback charger which I expect will run at around 200 - 300watts.
Dimensions will be roughly 280mm long, 80mm wide and 180mm high. Projectile will be about 35mm long and 4.5mm wide.
If it can achieve 3% efficiency, thats a projectile velocity over 50m/s cheesey Almost as powerful as an air rifle . .
I just need some more balsa wood, PCBs and etchant!!! and some more spare time.
I'll upload all the schematics and diagrams tomorrow, after I've turned them from chicken scribble into something legible.
Renesis
Mon May 11 2009, 06:07PM
Renesis Registered Member #2028 Joined: Mon Mar 16 2009, 08:13PM
Do you need some inspiration? This magnetic rifle was posted on the geek group a few days ago: Link2
big5824
Mon May 11 2009, 09:58PM
Do you have one bank per coil, or are you using the same bank to run both coils like me?
Camel
Tue May 12 2009, 05:58AM
Two banks, one for each coil. Both coils have 990uF banks + a 100uF 400V V-switch cap. The second coil has a few less layers than the first one, so it'll dump its energy quicker before the SCR gets turned off.
Link to schematics: Link2
Camel
Sun May 17 2009, 04:31AM
I am pretty sure the hardest part of this gun is the spring loaded clip. I'm making my 4th spring and I'm waiting for my second clip to dry. The first springs had bits that were too wide or too long so they kept getting stuck in the clip. This spring is pretty good, and the new clip that is drying is made of plywood. The previous one was made of balsa wood and I think the metal spring was digging into the side which also would cause it to stick . . .
I think i'll pour a heap of graphite powder into it for lubrication.
Anyone else made a spring loaded clip? Got tips?
