  • Guests: 32
Sanchez (36)
Knarvel (13)
10/16 Sanchez (36)
10/16 Knarvel (13)
Where can you buy getters?
jpsmith123
Thu May 14 2009, 03:03AM Print
Does anyone know where to buy SAES getters? I saw a thread here where someone had some, but IIRC the source wasn't mentioned.
GeordieBoy
Thu May 14 2009, 01:32PM
jpsmith123
Thu May 14 2009, 04:31PM
Well of course I'm aware of the SAES corporate web site. I was wondering where I could get a small amount of "off-the-shelf" getters for hobby/experimental purposes without having to go back and forth requesting information, quotes, etc., filling out forms with personal data, explaining the application in detail, etc.
Thu May 14 2009, 05:11PM
In case it hasn't been posted here before -- here is a ham who scratch-built a batch of triode tubes, made a radio with them, and used it to communicate across the Atlantic Ocean. He doesn't seem to uses a getter, but bakes the guts pretty well with an oven, and an induction heater, and its own heater while the tube is on the vacuum pump. (11:45 to 12:30) At that level of homebrew technology, I imagine it would not be hard to make a getter.
http://dailymotion.virgilio.it/video/x3wrzo_fabrication-dune-lampe
or
http://paillard.claude.free.fr
The second reference has links to articles (in French) giving lots of technical details, with diagrams and photographs.
What are you making that wants gettering?
Rich
Thu May 14 2009, 06:42PM
Getters can help pull a harder vacuum than can be achieved otherwise, and help the lifetime of the tube. Have you been inspired to start glassblowing, jpsmith123, or just researching?
Try asking him where he got his. Link2
jpsmith123
Thu May 14 2009, 08:20PM
Uzzors wrote ...
Right now I'm just researching and accumulating some hardware and parts. (So far I have a two stage rotary vane vacuum pump, some molecular sieve material, a thermocouple gauge and various hardware odds and ends).
Anyway it seems to me that if a pulsed HV source were used, e.g., a Marx generator, the tube could be made fairly small and the vacuum requirements would be modest - say in the range of a few millitorr or so.
I'm also trying to figure out what would be the highest pulsed voltage that could be feasibly (and reasonably cheaply) generated and utilized (in a typical home workshop); a MV or 2 would be nice but maybe not practical. Right now I'm looking at several papers on HV air-core pulse transformer design and trying to do simulations using spice and CST studio.
I don't think it would be feasible (for me) to do anything with glassblowing. I suppose I will try to use off-the-shelf glass (or ceramic) to metal seals, maybe something with small conflat flanges and copper gaskets.
Depending on what type of getters are available, it might be feasible to make a sealed-off, demountable "semi-permanent" electron diode.
Hon1nbo
Thu May 14 2009, 09:05PM
United Nuclear lists their calcium metal as suitable for vacuum "getters"...
Fabio
Thu May 21 2009, 01:55PM
Fabio Registered Member #122 Joined: Fri Feb 10 2006, 12:55PM
i have a friend that work in a vacuum tube factory, scrounging some getters and some trashed glass items isn't so hard.
Almost all of glass to metal seals readly available on the market require some glassblowing job:
Making a glass to metal seal (except for wires and really small pins) is a tricky and time consuming job that usually require a large quantity of molten glass in ovens and a really slow cooling, at the contrary, a glass to glass and a metal to metal joint is much more easy and can be made with a torch, this is the reason why almost all scientific glassblowers usually prefer a pre-maded glass to metal seals for their tubes.
anyhow, a basic glassblowing tecnique isn't so hard to learn, and you could probably made your first working 2 electrode tube in 5-10 tries cheesey
Ciao!
Fabio.
MinorityCarrier
Thu May 21 2009, 03:37PM
Long ago I worked at Hughes Aircraft - Carlsbad CA, where they had their vacuum tube/DVST manufacturing division. Glass-to-metal sealed pins were used in vast quantities, and each lot had samples inspected for glass whetting integrity prior to approval for use. You can't just blop some molten glass on a metal pin and expect it to seal. You should be able to buy these pins from some one.
Glass blowing/welding isn't that hard, but the trick is the post weld annealing to remove stress, otherwise you will watch in horror as your beautiful welds suddenly form cracks everywhere.
Conflat flanges with insulated electrical feed-throughs are certainly a viable option, but you need the other side, the thing you're bolting it to. And copper shear gaskets are use-once only. so have a bunch of them. Also may help to have a helium leak detector handy to check all conflat seals.
Tesladownunder
Sat May 23 2009, 08:53AM
I suggest asking a neon workshop to buy a few cold cathodes from them. They act as their own getters. They are not expensive and even have the glass-friendly leads.
