  • Guests: 72
Sanchez (36)
Knarvel (13)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
Negative edge monostable
Camel
Sat May 09 2009, 04:34AM Print
Camel Registered Member #1694 Joined: Sat Sept 13 2008, 09:13AM
Hi,
I need to build a negative edge detector circuit that will produce a 50mA pulse for about 5 microseconds. I have read the 555 will do this, but I'm not sure how. Can anyone help?
Thanks
Sat May 09 2009, 06:04AM
Take a look at the staccato controller used for VTTCs, it is a negative edge detector.
This is some scope shots from the one I built, sorry about the translation, but I have yet to write it in english myself: Link2
Z28Fistergod
Sat May 09 2009, 04:36PM
Z28Fistergod Registered Member #2040 Joined: Fri Mar 20 2009, 10:13PM
I'm almost positive the datasheet for the 555 has the schematic for a monostable timer, and it will trigger on the falling edge like you want.
Camel
Sun May 10 2009, 05:19AM
I found a 555 monostable multi vibrator in the falstad circuit simulator and just tuned the capacitor until the pulse length was right. But thanks anyway.
