  • Guests: 30
Sanchez (36)
Knarvel (13)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
measuring inductance
Solidacid
Thu May 07 2009, 07:27AM Print
Solidacid Registered Member #1430 Joined: Sun Apr 06 2008, 11:12AM
i was wondering if you guys could help me find a way to measure the inductance of various inductors.
i have mutimeters but no oscilloscope(i might be able to borrow one)
i was thinking i could use
Schematic1
from powerlabs.org
on the site it says "The frequency of operation is automatically adjusted to resonance"
if i put my inductor in the flybacks place maybe i could somehow measure the frequency of the pulses?
i need to measure inductors both with air and various other cores
any ideas?
EDIT:
i have an arduino, maybe i can somehow use that? that would also eliminate the need for a screen, as i can just plug it into my USB port
Dr. Slack
Thu May 07 2009, 10:29AM
Measurement of inductors is one of the trickier things to do, especially as there are many different types and they are one of the least "pure" components, having loss, stray C, saturation, all things which often make it important what frequency and drive level you use to excite them.
A good way to get an idea of the L is to make an AC current source. At low frequency this can be done by putting a big resistor in series with the LV outupt of an AC transformer from the mains. Put this current through the unknown inductor, and measure the voltage drop. Measure its DC resistance as well. If the calculated AC impedance is an order of magnitude or more than the DC, then you have a good measurement of the inductance.
Mains frequency is so low that it will only tend to be good for mains components, transformers and flourescent chokes for instance. The inductance of higher frequency components may be difficiult to measure this way.
Resonance is good for higher frquencies. Use a sig-gen program to drive the unknown L connected to a known C (most of us have a known C lying around somewhere, it's worth buying one if you haven't), sweep the drive frequency until the audio output peaks (or nulls depednign on how you have it connected), and do the sums from frquency and C to get the L.
Thu May 07 2009, 01:06PM
Here is a well thought-out coil measurement system from Nuts & Volts magazine, Feb 2008. It can also measure capacitors and other devices. In one of the examples they measure the impedance of a 40m antenna. All it requires is a signal generator, voltmeter and a few components.
I've reprinted the article with permission from the author: Low Cost Impedance Analyzer
It could be what you're looking for.
Cheers, Barry
Life is like an analogy.
Thu May 07 2009, 04:56PM
You can measure the frequency of an oscillator in which the unknown inductor and a known capacitor form a tank circuit. One popular circuit uses a common voltage comparator, for example the core of the project at
http://electronics-diy.com/lc_meter.php
All you really need is the LM311, a handful of R's, one L and one C, and a way to measure the frequency. Many digital multimeters have a suitable "frequency" range. You can get within a couple of percent with headphones and a bit of musical talent. This particular circuit works over a broad, but limited, range of characteristic time -- sqrt(LC) -- and impedance -- sqrt(L/C). Helped me to make 50 uH 30 A air-core inductors for a 3-phase LISN (one-off, uncertified).
To echo Dr. Slack: physical inductors (esp. those with ferromagnetic cores) are imperfectly represented by the ideal circuit element. Beware of sensitivity to frequency and current.
-Rich
Thu May 07 2009, 05:52PM
Solidacid wrote ...
On that site it says a lot of things. The frequency of operation of that circuit has absolutely nothing to do with resonance, the circuit switches off when the transistor can no longer hold the collector current, which depends on its gain, base current, winding inductances etc.,etc...
Thu May 07 2009, 07:20PM
I bought one of these, they are actually pretty precise, but the leads are a bunch of crap.
Ive only been happy about that buy :)
Solidacid
Thu May 07 2009, 10:12PM
i might buy one of those :D, i can add it to my collection of 5 multimeters :P
but i still need a "ghetto" way of measuring inductance :(
i was really hoping i could use my arduino..
Fri May 08 2009, 08:45AM
I've built the PIC based LC meter in the above link and it works well. The capacitance range isn't excellent, as it bums out somewhere below 1µF, but it's great for inductors. Their are plenty of AVR LC meters you can build, also with the Arduino. Link2
PanosB_GR
Fri May 08 2009, 09:51AM
PanosB_GR Registered Member #1680 Joined: Fri Sept 05 2008, 04:19PM
One good oscilloscope is a sound card.
You can output sinusoids from the soundcard, ranging up to whatever is the card sampling rate (96kHz for good ones) and record the voltage to the input channel. Just put the inductor across.
Measuring the frequency responce of this setup is the best way of determining the inductance.
And it is "ghetto" enough. cheesey
twist2b
Sat May 09 2009, 01:27AM
twist2b Registered Member #2086 Joined: Tue Apr 21 2009, 02:33AM
You sure you want to use that schematic? It really is not to friendly with the 2n3055. The author admits he, himself went through a couple, not to mention the heatsink it needs o_O
Klugesmith - That is awesome... I always wanted to build something like that :)
Anyways, There is a 555 Timer schematic that is alot better, and still simple.
