  • Guests: 43
davovinch (75)
Duncan (37)
Vatorius (60)
waicool20 (27)
12/11 Forty (38)
12/13 williamn (48)
12/13 ReddyK (57)
Coherent laser - what's wrong with it?
c4r0
Fri May 01 2009, 10:48AM Print
c4r0 Registered Member #151 Joined: Sun Feb 12 2006, 02:53PM
Hi all!
Recently I obtained a coherent laser head Link2 Link2 . It works fine but I noticed a small spot of light next to the proper spot. It's weak but clearly visible. It's about 1-2cm from the proper spot in about 3m distance from the laser aperture, this is how it looks like:
1241174605 151 FT0 Img 1581x
I wonder if this is a trifle or a serious damage. The aperture is clear so I think it's not the problem. The head is powered from a dedicated controller.
Fri May 01 2009, 06:23PM
It looks like a reflection off of something, which could be a sign of things being knocked out of alignment (but really its probably a manufacturing defect, which might be related to why you got it). It is also possible that the laser is lasing in a slightly tem01 mode, and tweaking the temperatures/currents might make it go away. Are you using the matching controller for the laser?
big5824
Fri May 01 2009, 08:30PM
is there any small scratches on the lense? even a tiny one could be enough to refract a decent portion of the light.
c4r0
Fri May 01 2009, 08:46PM
Yes, I'm using dedicated analog controller Link2 . This laser has been working in a computer-to-plate system. The guy who sold it to me had also other parts from that machine so I think he just disassembled for parts so the laser might have been good.
I can't find any scratches on the aperture glass.
EEYORE
Sat May 02 2009, 12:41AM
If the laser head was dismantled, it could be out of alignment. DPSS lasers need careful alignment. Did you get this on ebay? Ask the seller LOTS of questions about lasers before buying to make sure they arent selling you junk.
Matt
c4r0
Sat May 02 2009, 08:56AM
The head hasn't been dismantled, the case lid is soldered and it looks to be in good condition. I didn't buy it on ebay and It was so cheap that I couldn't complain even if the laser head case was empty :P Thank you guys for your response :)
plazmatron
Sat May 09 2009, 03:18PM
Satellite beams like that are not uncommon, and wouldnt normally be considered a defect. Its probably a secondary reflection off of the output window. It is definitely not mode related.
c4r0
Tue May 12 2009, 10:30AM
Thats exactly an answer I was looking for, thanks! smile
