  • Guests: 61
Weird Plasma Speaker Arcs-- HELP
fatboyslim
Fri Apr 24 2009, 09:38AM Print
fatboyslim Registered Member #1779 Joined: Sat Oct 25 2008, 11:05AM
Hi
I Have built plasmaman's plasma speaker and it was working fine. I had recently changed the TL494 IC chip and it contined to work fine. All of a sudden though the sparks started to become very noisy and flapping. it drowned out the sound of the music. no matter how close i bring the two wires together the spark buzzes. i cannot achieve a soundless spark. I tried adjusting the pots but to no prevail. Can somebody please help me.
This is what the spark looks like now http://www.youtube.com/watch?v=1Y5DZtMYyXw&feature=channel_page]
The schematic of the circuit is here http://www.instructables.com/files/deriv/FSN/TLXV/FMMD1ALS/FSNTLXVFMMD1ALS.MEDIUM.jpg]
Mind you this is what the sparks USED TO LOOK AND SOUND LIKE http://www.youtube.com/watch?v=fmYdjXcgBss&feature=channel_pagel]
HELP would be much appreciated
Thanks
Fatboyslim
Fri Apr 24 2009, 09:45AM
I see you "changed" the electrodes, this can have an impact on the arc stability.
If changing the electrodes back does not help, I guess some component got damaged, try replacing the 494 chip.
fatboyslim
Fri Apr 24 2009, 10:22AM
It makes the same kind of sparks with the electrodes. If the chip was damaged then would it still work? i am running 14v through it from batteries. could the MOSFET be damaged?
Fri Apr 24 2009, 11:50AM
fatboyslim wrote ...
Yes, these chips often fail partially and only some functions become "degenerated".
Of course the MOSFET can be damaged.
teslacoolguy
Fri Apr 24 2009, 02:11PM
what frequency are you running it at? It could be that when you changed the tl494 chip the frequency got messed up. It should be running at around 100khz.
Littlew
Fri Apr 24 2009, 04:14PM
Littlew Registered Member #1448 Joined: Sat Apr 19 2008, 01:16PM
looks like something in schematic is dead( maybe tl494)
try to replace it with new tl494
fatboyslim
Fri Apr 24 2009, 07:28PM
OK thanks. Ill try replacing the part and tell you how it goes. are there anyother parts that have the possibilty it was damaged so i could replace it?
Antonio
Fri Apr 24 2009, 09:12PM
The schematic has something wrong. Pin 9 of the TL494 is the emitter of a driver transistor, that has the collector on pin 8. There is nothing in the schematic to discharge the gate of the MOSFET and turn it off. Add a resistor between pin 9 and ground. 1 kOhm is probably enough. And make it sure that the circuit is grounded.
Fri Apr 24 2009, 09:32PM
Pin 10 should also be shorted to pin 9 in order to parallel the internal drive transistors.
