  • Guests: 58
electricity for x ray tube
borri317
Fri Apr 17 2009, 02:33PM Print
borri317 Registered Member #664 Joined: Sun Apr 22 2007, 10:31PM
I bought x ray tube from ebay and now i need electricity for anode. Where do i get 75kV for it?
Fri Apr 17 2009, 02:49PM
A Cockcroft and Walton generator driven by a large old-fashioned television AC Line Output Transformer ('flyback') can provide about 3mA @ 75kV (if it is well made) which is enough to run a dental X-ray tube at medium power. (I guess yours is a dental tube because of the voltage)
If you need much more current than that, you must be prepared to pay for it! smile
borri317
Fri Apr 17 2009, 03:29PM
I hava ac flyback, 10 10kV 1n capacitors but i cant find diodes.
Fri Apr 17 2009, 03:50PM
borri317 wrote ...
Several companies in China sell HV diodes through ebay at very good prices. I have bought from them and found them honest and the parts reliable. (Most of the world's electronic parts are manufactured in China nowadays)
See:
borri317
Wed Apr 22 2009, 01:34PM
I dont have paypal so i have to buy expensive diodes from shop. What parts i should use for zvs flyback drive? I tried it once with buk456-60a fets and 1n4007 diodes and i didnt work. Should i put some kind of resistors to voltage multiplier to protect diodes from too much current? Should i use 12kV 550mA microwave oven rectifiers or 25kV 25mA rectifiers?
Wed Apr 22 2009, 01:58PM
You are going to need faster diodes than those. Maybe a few strings of uf4007? Those are cheap, and 1kv at 1 amp. Though i am not sure that 10kv capacitors would be good. I would use higher voltage rating, chances are the LOPT puts out too high of voltage.
Wed Apr 22 2009, 03:01PM
Anything to do with X-rays has, in my view, to be constructed to a very high standard, so you'd be better waiting until you can get suitable parts than start off with improvisations which are likely to be unreliable.
You will also need some means of measuring the X-rays, such as an ionization chamber, proportional counter, or other dosimeter, (but not a GM counter) and an adequate amount of lead for shielding, a mirror trap, a 100kV potential divider to measure the anode voltage, and so on, before you can begin your experiments in safety.
A high voltage supply is the least of your problems here! smile
borri317
Wed Apr 22 2009, 03:59PM
Radiation shielding is least of my problems. When i go to buy diodes i also buy resistors for that divider thing. What kind of diodes and capacitors i shoud use? I dont have 10kV 1n capacitors i have 15kV 1n capacitors.
3l3ctrici7y
Wed Apr 22 2009, 06:31PM
3l3ctrici7y Registered Member #1806 Joined: Sun Nov 09 2008, 04:58AM
Harry, what is a mirror trap?
Is it like a bullet trap Link2, only for em radiation?
3l3ctrici7y
Wed Apr 22 2009, 06:36PM
borri317, have you considered using an ignition coil?
They're extremely easy to run directly off of the mains, and when doing so, produce significant output.
As has been stated before, you do not need to rectify the power to the xray tube, as it will self rectify (that is what it is after all, an ultra high voltage rectifier)
I've not personally tried this, but it seems reasonable that it could work.
See this youtube video... Link2
