  • Guests: 35
12/13 williamn (48)
12/13 ReddyK (57)
12/13 Birdman (31)
Project box for SSTC?
Chris Cristini
Tue Apr 21 2009, 05:20PM Print
I have this subwoofer box and I think it would work great for my second SSTC it has a nice enclosure for the mosfets primary and secondary and on the other side it has lots of room for gate driver circuitry.What do you think?
1240334301 1749 FT0 Picture 018 Large
1240334301 1749 FT0 Picture 019 Large
1240334301 1749 FT0 Picture 024 Large
1240334370 1749 FT0 Picture 010 Large
Plasma Lover
Tue Apr 21 2009, 06:05PM
Plasma Lover Registered Member #1911 Joined: Mon Jan 05 2009, 06:30PM
Don't you think that it would look a bit too bodged? I suppose if you rounded off the circle's diameter and gave it a nice sand and paint job (if it's not the MDF board, as you can't exactly sand it).
I think that the speaker box has great potential and it was a good observation on your part to realize that. Just make sure that the box has no metal in/on it that could come near the secondary coil.
Tue Apr 21 2009, 07:23PM
Certainly depends on the size of the SSTC you intend to build, my version of steve wards sstc5 was fitted into a lunchbox with exterior heatsinks.
So I think its way too big unless you start talking input power above 1-2kW.
Chris Cristini
Tue Apr 21 2009, 09:04PM
I think something like this Link2 but using two or four IRFP460's Full or Half bridge I don't know yet maybe try some idea's like using a 6" OD PVC pipe and make an internal primary I have asked about it before here Link2 That my be some thing cool to try. I decided to whip up a quick heat sink set up and put a few old semiconductors on there for reference one step closer. I can use TL494's for a good adjustable gate driver right?
1240347756 1749 FT68161 Picture 001 Large
1240347756 1749 FT68161 Picture 002 Large
1240347756 1749 FT68161 Picture 003 Large
1240347756 1749 FT68161 Picture 004 Large
1240347756 1749 FT68161 Picture 005 Large
1240347756 1749 FT68161 Picture 007 Large
1240347756 1749 FT68161 Picture 008 Large
Killa-X
Thu Apr 23 2009, 01:35AM
Subwoofer, Shouldn't have a problem at all fitting a SSTC circuit into that. I was going to build a Mini SSTC using Steves circuit, and I got a old speaker, like 6X4X3 maybe? I took the large speaker out for ATMEGA644P program messing, and I figured maybe the case can be a SSTC.. It has 4 terminals so :D
Good luck Chris Cramer!
Chris Cristini
Thu Apr 23 2009, 03:00PM
I like this full bridge setup. Link2 Can I make a more simple oscillator and gate drive than this. Link2 And I want to thank Steve Ward for all of his info. smile
Thu Apr 23 2009, 03:51PM
Chris Cramer wrote ...
Use the driver from the mini sstc, it can drive a fullbridge without problems: Link2
