  • Guests: 43
Removing capacitor from flyback
Franky
Sun Apr 19 2009, 02:45PM Print
Franky Registered Member #1940 Joined: Tue Jan 27 2009, 02:34PM
Hi
I have a question about my new flyback.
The flyback contains a capacitor in the HV section.
Is it possible to remove this capacitor? It is ruining the spark of my plasma speaker :(
Here is a picture of the flyback.
I got the flyback from a philips IDTV.
Sun Apr 19 2009, 03:55PM
I don't actually see any capacitor - do you mean the potential divider for the screen supply with the two variable resistors on the front?
Sun Apr 19 2009, 03:56PM
Really? That transformer looks to me like it does not have any capacitor. The rectangular thing is the focus/screen divider for the CRT, and the cylinder under the HV lead is probably the rectifier stack; it looks too slim to be a HV cap.
How is it ruining your spark?
Edit: Too slow!
Antonio
Sun Apr 19 2009, 05:52PM
Practically all flyback transformers used in monitors have an internal capacitor and a rectifier. You can disconnect it insulating (with hot glue) its ground pin, that is one of the pins under the square box. You can cut the pin too, leaving less to be insulated. I prefer to keep the pin.
I don't see the capacitor ground pin in the picture. Maybe is the same visible under the potentiometers, or really there is no capacitor.
Sun Apr 19 2009, 06:28PM
A flyback have some selfcapacitance that will store a smaller energy, enough to give a good zap.
Sun Apr 19 2009, 06:45PM
Antonio wrote ...
That is true, and most transformers used in TVs are capacitorless smile and thats where Franky got his one.
lhl_henrylui
Mon Apr 20 2009, 04:51AM
lhl_henrylui Registered Member #1498 Joined: Thu May 22 2008, 07:08AM
I have a FBT with internal capacitor.Can I use over voltage to break the capacitor.
Mon Apr 20 2009, 06:33AM
lhl_henrylui wrote ...
You will short it and get no output.
Look if the cap does not have a separate GND connection in which case it can be insulated and you can still use the FBT for moderate output voltages.
Franky
Mon Apr 20 2009, 09:21AM
Antonio wrote ...
The following thing happens.
When I cut off the power, you can hear the flyback leaking power. When you wait 30 sec (after cutting the power) and bring the two HV connection close to each other, you can see and here a spark (0.5cm).
I tried to use this flyback for my plasma speaker. The sound is horrible, unless I make the spark less the 1cm. I think that some of the sparks are stored in the capacitor.
Here is a picture of my flyback
Edit:
Another picture
Mon Apr 20 2009, 09:44AM
For a audio modulated flyback I would take the core out of a modern flyback and then wind your own secondary on a piece of yellow PVC, just one layer of wire. This will give a way shorter arc but a nice and stable AC output smile perfect for audio modulation.
