  • Guests: 37
Van der graaf generator issues
PerksPlus
Sun Apr 19 2009, 04:48AM Print
PerksPlus Registered Member #2084 Joined: Sun Apr 19 2009, 04:31AM
I attempted to make my first generator today. It's not working at all maybe someone can spot my problem.
Materials:
Rollers: Axels are made of wooden pegs, rollers are styrafoam covered in pvc pipe coated with double sided tape then the triboelectric material is attached. Top roller is coated in teflon tape , bottom is coated in aluminum foil.
housing: A thick cardboard tube.
Brush: a T.V. Antenna cable taped to the bowl, stiffened with tape and a coat hanger wire. It is about a centimeter directly above the belt.
Sphere: two stainless steel(?) salad bowls taped togeather (tape is on the outside).
Belt: a type of ribbon, it is a thin stretchy plastic. it gets folded a bit on the bottom roller, but I don't think the negative side ever actually touches the positive, it is fairly tightly on the rollers.
Motor: a drill attached to a free end of the bottom peg.
Misc:
The mechanism works fairly smoothly, the rollers roll. the belt stays on them and in the middle.
the bottom of the housing is open, and about 2 inches from the floor, there is no brush to ground it does this matter?.
I think the problem might be Humidity, or that I got a small bit of oil from my hands on the belt, I was however trying to avoid over handling, and only ever touched it a few times. But maybe my materials are out.
Any help or information would be greatly appreciated THANKS!
1240116072 2084 FT0 0418092044
1240116072 2084 FT0 0418092136
Antonio
Sun Apr 19 2009, 12:31PM
Cardboard tube? Not enough insulation (by several orders of magnitude). Use a PVC tube.
A brush to ground at the lower roller is absolutely necessary, as well as a brush to the terminal at the upper roller. "Ground" here can be just the base of the machine, if not made of a highly insulating material.
You will need a more solid construction of the bearings if you want the machine to last more than a few minutes.
Steve Maurer
Sun Apr 19 2009, 12:46PM
Steve Maurer Registered Member #133 Joined: Fri Feb 10 2006, 10:27PM
Antonio has a very good point concerning the material of the tube. Cardboard readily absorbs moisture and will easily conduct current between your collector and the bottom of your generator at the high voltages involved. This leakage current may be sufficient to bleed off the collector charge before it has a chance to develop the high potential voltage that the generator is designed to produce. I would definitely replace the cardboard tube with a good plastic insulator support.
Best regards,
Steve
PerksPlus
Mon Apr 20 2009, 12:17PM
I didn't like the idea of using that tube or the welfare berring idea either, but I'm poor.
anywho round 2, I tried something a little smaller its just as jerry rigged, But I can't see why this one won't work :(
Same sort of deal, top roll is teflon coated, bottom is aluminum foil. Its got the same synthetic plastic/rubber sort of belt. and that bottle its housed in is made of plastic. I'm running it with a drill.
the bottom brush is grounded to whatever I can find thats big and metal.
Its hopeless isn't it lol.
1240229840 2084 FT67982 0420090438
1240229840 2084 FT67982 0420090509
Mon Apr 20 2009, 01:49PM
PerksPlus wrote ...
Not if it makes sparks, it isn't.
Cheers, Finn Hammer
Antonio
Mon Apr 20 2009, 03:06PM
What is that wire across the plastic tube? A Van de Graaff machine does not generate arcs. A pointed wire close to the terminal will drain all the charge silently. Make it sure that everything is very dry. Use a hair drier to heat the machine if necessary (be careful to not deform the tube).
Mon Apr 20 2009, 04:35PM
What kind are you talking about? The two-wire cable, who's wires are about half an inch from each other?
If my understanding of Van De Graaffs is correct, a better brush would be 12 or so gauge stranded wire, with each strand separated. This would be a bunch of different conductors. Also, shouldn't it lightly touch the belt?
The dryer the environment, the better. Otherwise you leak charge faster. This is bad since it is static, and has no real current.
And a bit off topic, Steve, i love Pensacola! cheesey
PerksPlus
Mon Apr 20 2009, 10:12PM
That wire in the first pic is attached to the brush which is attached to the can when its in place.
I thought that the current gets inducted into the wires (don't need to physicaly touch the belt). I may be wrong though. thanx for the support
PerksPlus
Mon Apr 20 2009, 10:50PM
kewl, not sure if it was the hairdryer, or getting the wires to physically touch, or taping over the sharpish edges, but it definately works.... half ass, but I get about 2cm sparks lol thanks for the help again guys!
Antonio
Tue Apr 21 2009, 12:12AM
You can see that this machine is not very critical. The belt doesn't induce currents, but due to the high electric field, the air between it and pointed wires close to it gets ionized and conducts electricity. The brushes connected to the terminal and to ground shall not touch the belt, but just have points close to it. They can touch the belt, if you use very light brushes that will not damage the belt, but this is not necessary.
