  • Guests: 35
120V monstrous ZVS driver for custom flyback transformer
Chris Cristini
Wed Apr 15 2009, 09:22PM Print
This is just an idea but if you use large anough mosfet's and make a huge flyback transformer with like 20 winds on the primary and as many winds on the secondary with reasonable thickness wire to handle huge amounts of power at very high voltage. It may be hard to rectify and smooth all that current but it would put out a nice arc im sure.
Wed Apr 15 2009, 10:12PM
In domestic television use, line output transformers (US: 'flybacks') are normally operated at around 115V.
Chris Cristini
Wed Apr 15 2009, 10:29PM
Wow I did not know they ran at that voltage in TV.s I always thought they were ran at 20V or so. I mean like this Link2 but at 120V at a couple of Amp's cheesey .
Mike
Wed Apr 15 2009, 10:45PM
the problem with flybacks is when you drive to very high levels the secondary begins to arc over inside and eventually just melt. if you use thick enough wire to stop this from happening you wont get nearly as high voltage output as you would with the tiny magnet wire that is normally used.
Myke
Wed Apr 15 2009, 11:07PM
One problem with the ZVS flyback driver is that as you increase the voltage input to the driver, it becomes harder and harder to aviod parasitic oscillations. That's why most people use other driver topologies at high powers.
Big MOSFETs tend to have large gate capacitances and so to keep the MOSFETs out of the linear range of operation as much as possible, you would need to decrease the resistance of the pull up resistors. You could also lower the oscillating freq so that the tine the MOSFET is in linear operation is kept a small percentage of the cycle.
Arcing shouldn't be a problem if you make your own secondary because you can pretty much make the insulation as thick as you want. You would need some filler insulator to prevent corona at high voltages though.
Chris Cristini
Wed Apr 15 2009, 11:08PM
Well can't you make your own on a bigger core and put it all in transformer oil and maybe the driver to?
Note. I need to obtain a large variac don't want to just plug things in.
Mike
Thu Apr 16 2009, 12:27AM
I think if you want to have some fun make one of those full bridge resonant drivers and just destroy a couple flybacks. I have seen a few threads on the forums of people pulling foot long arcs out of flybacks before killing them!
Firefox
Thu Apr 16 2009, 12:52AM
Firefox Registered Member #1389 Joined: Thu Mar 13 2008, 12:50AM
I think once you pass the point (50-80Vin) when it is tough to keep paracitic oscillations out of the ZVS driver, the SLR topology becomes superior. While the ZVS flyback driver can pull massive currents at low voltages (tough with the SLR topo), limiting current draw becomes the problem at higher voltages, which the SLR topokogy does by nature.
Chris Cristini
Thu Apr 16 2009, 02:03AM
Firefox wrote ...
SLR topology?
Thu Apr 16 2009, 02:07AM
Firefox wrote ...
Firefox seems to have hit it head on. That sounds about right. The current would indeed be insane. Also, the mosfets would have to be good. I have seen a 120 mains powered zvs sstc though. Exact same schematic.... Not sure whats up with that but the sparks where about a foot or something.
