  • Guests: 37
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
Any idea how this can be possible?
Arlecchino
Sun Apr 12 2009, 11:26AM Print
Arlecchino Registered Member #2078 Joined: Sun Apr 12 2009, 11:11AM
hi guys,
surfing the web i've found this mysterious device : Link2
does anybody knows if this can be possible? tongue
the same device ( i think ) on bigger scale : Link2
any idea how to build one?
Thanks in advanced!
1239535613 2078 FT0 2008727165849
1239535613 2078 FT0 0010 Sml
Sun Apr 12 2009, 11:29AM
RF electromagnetic field generator? The same reason why fluorescent bulbs glow near a Tesla coil?
Sun Apr 12 2009, 11:40AM
The top picture shows something which has been improvised out of a watch case and strap. I expect the cable leads to an RF generator of some kind, perhaps a TC, or even to Paint Shop Pro! smile
The second device seems to be fabricated out of PP3 battery clips.
A hoax of some kind, I'd guess, but who can say?
Arlecchino
Sun Apr 12 2009, 12:48PM
picture update :D
1239540524 2078 FT67471 200888161614857
I can see a 555 IC timer.... and that's all
Sun Apr 12 2009, 01:13PM
Could be using a simple HV generator (that large block in the top centre looks like a potted inductor). It *is* possible to generate tens of KV in a small space using a piezo transformer but IIRC they need 12V minimum.
I did find out that there is a hybrid system where they run two PZTs in series with inverse phasing, to get +/- 2KV and if you run them open loop (using a PIC based pulse excitation circuit) you can get over 6KV peak.
-A
"Bother" said Pooh, as the laser diode fell off its mount...
hotcrazyfruit
Sun Apr 12 2009, 04:25PM
hotcrazyfruit banned on 5/26/2009
Registered Member #1877 Joined: Mon Dec 22 2008, 02:03AM
The second picture is very easy to say that its a simple electromagnet. you can see the coiled wire in the far clear section, and obviously uses 3 - 9volt batteries to power it...
Hon1nbo
Sun Apr 12 2009, 04:37PM
Conundrum wrote ...
you can get 12V in a pretty small package, but they don't last very long IIRC
my guess is that instead of making an RF source of tens of KV, make one fot driving the driver built unto the compact flourescent, as the bulb is the kind with the driver built in... but the watch nay just as well be tens of kV... Emco makes VERY small, self contained units (since they were light and small enough, I have plans to build a lifter based on one, so that way the entire lifter would be self contained).
Sun Apr 12 2009, 06:16PM
Is that IC not a crystal oscillator? If so it is some kinda RF device cheesey
Arlecchino
Sun Apr 12 2009, 06:27PM
i think its a IC... not sure anywayz....
Sun Apr 12 2009, 06:29PM
I wonder what the Oriental writing says it is.
