  • Guests: 29
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
Microwave fan speed control
Sat Apr 11 2009, 03:54PM Print
As a preparation for the upcoming summer which will surely be hot, I'd like to build a speed control for my microwave fan.
I quickly found out that the classic "dimmer" circuit tends to burn the windings out at low settings, as it has a tendency of passing just one half wave of the mains waveform.
Then I came across this PDF which presents a novel way of controlling inductive loads by a dual-triac circuit Link2 . However I have no idea how to calculate the component values.
Has anyone build that circuit and could share his component values?
Or is there a simpler circuit which could be used to control small induction motors?
Sat Apr 11 2009, 04:19PM
I built the "Figure 11. Power variation circuit for arc welding transformer" circuit once, and it worked well for various loads, IIRC. I just used the the values in the schematic.
Sun Apr 12 2009, 08:42AM
Hmm, 7 watt resistor, not sure if that's a good way of controlling a ~30W motor cheesey
I found a nice motor control IC, the U2008B, so Ill give it a try.
