  • Guests: 56
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
inertia of a rotating rectangular prism about an axis on it's side
cavemen
Thu Apr 09 2009, 03:01PM Print
cavemen Registered Member #2008 Joined: Tue Mar 03 2009, 05:11AM
How do i find inertia of a rectangular prism rotating about an axis on it's side?
Untitled
Thu Apr 09 2009, 05:35PM
by using the parallel axis theorem. Link2
hint-you don't care about the 'thickness' of the block (as measured parallel to the axis of rotation) and you can think of the block as a square plate with negligible thickness and really high density.
cavemen
Thu Apr 09 2009, 09:32PM
i am not the math guy
the parallel axis theorem looks to me just like a hole set of chinese characters, but as far as i understand:
I = ( [1/3] * mh^2 ) + m*(w^2 + l^2) * [1/12]
Is this true?
How do I know the formula if the axis of rotation is not all the way to the side?
If I have a flywheel that has an angular inertia of "I" and I put a second, identical flywheel on the same axis would the moment double?
[Edit: Please no double posting]
