  • Guests: 54
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
Two Mini CRT Tubes
MRacerxdl
Thu Apr 09 2009, 12:40AM Print
Hi all, in the last week, I got two Working Sony CRT Screens, with all the circuit working, so I can use as a display for composite video...
Here is a pic of one of the two displays:
I already did that:
What other things that I can do with that tubes ??
Hon1nbo
Thu Apr 09 2009, 01:53AM
a good, classic project for CRT is an oscilloscope... very easy to make, and just plain old fun!
Thu Apr 09 2009, 05:29PM
i have one of those "flat" B/W CRTs here, the driver board is a crispy critter (rain!), but it seems intact. Any use?
had a cool idea to use a PIC + lookup table to dynamically remap the scan onto the curved plate so that it can be used as a scope/spectrum analyser/etc.
MRacerxdl
Thu Apr 09 2009, 10:44PM
I was thinking about make a simply scope or so, but I think it will be MUCH simply, because actual scopes use Capacitive Beam Deflection that can operates in much higher speeds than the coil deflection... Maybe if I rewound the coils?
Hon1nbo
Fri Apr 10 2009, 12:34AM
Mestre Racerxdl wrote ...
it depends on what you would use it for.. for audio frequencies, it should be fine... otherwise, good luck rewinding those things in a useful way!
but the nice thing about that little mod is that no modifications done are permanent... as long as you do not physically destroy the connections from the deflector coils to the main board, and most TVs will operate just as they think "normal" if you disconnect the four pin connector from the coils that goes to the board, and attach a seewp voltage to the horizontal deflections, and your test source to the vertical...
but it's your project, do whatever you want.
MRacerxdl
Fri Apr 10 2009, 05:15PM
Hmm, as you can see in this video Link2 , I already did something like that once, but it didnt work good, its a a few hundreds of hertz square wave turns in a Charge/Discharge cap waveform... For sine wave works very good (as you can see in the video)
