  • Guests: 45
Noelle (43)
King_of_Junk (36)
Ixz (35)
geobruce (31)
tulkas (32)
Gregory (31)
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
solar dumpload controller
Avalanche
Sun Apr 05 2009, 08:02PM Print
This is something I've been wanting to do for ages...so this weekend I've finally motivated myself to get on with it cheesey
Outside on the garage roof I have a 50W panel, that has sat disconnected for the last year or so. It's intended for a 12v system, so open circuit voltage is about 19-20v in good sunlight. I also have 3x86Ah Yuasa batteries, that have also sat around doing nothng except the occasional recharge. When I first bought the panel, I also bought a cheap solar charge controller, which turned out to have simple 'bang-bang' type control, around about 14.4v. With 20m of cable going to the panel, the bang-bang could be heard very well on any radio! Adding some filtering helped with this, but I finally wrecked the controller by trying to change the float voltage from 14.4v to 13.65v (it has about 7 pots inside and I lost track of them all).
Anyway, to the point... here's what I will hopefully be replacing it with soon. It's a different topology, instead of switching the panel into the batteries, the panel is directly connected to the battery (through a diode!) and a buck converter puts a continuous current into a dumpload, which can be some distance away from the battery bank without causing RFI. A feedback loop controls the duty cycle of the buck converter, to hold the battery voltage at a constant 13.35v (eventually going to add an option to boost this temporarily to 14.4v). Some of you might have spotted that the buck converter will not put a continuous load on the battery bank...but hopefully this won't be a problem because the controller will be located right next to the battery bank, and the voltage divider is well filtered for the ADC. 7 segment just displays the battery voltage, it's sort of 'time multiplexed' from a single BCD to 7 seg converter to save IO pins.
Anyway it's powered by an ATiny24v, finishing the software is the next task. I haven't drawn a schematic, I just designed it directly onto the stripboard cheesey
I've written too much so I'm gonna shut up and post the pics...
1238961513 103 FT0 P4050005 Medium
1238961513 103 FT0 P4050002 Medium
