  • Guests: 31
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
Recharging batteries
Solidacid
Fri Apr 03 2009, 03:53PM Print
Solidacid Registered Member #1430 Joined: Sun Apr 06 2008, 11:12AM
a few days ago, my dad brought home an old cordless drill, it's a cordless bosch psr color 2.4v.
also, i recently acquired 2 batteries for cordless drills that my school was throwing out(they couldn't find the drills), one is a 12v Ni-Mh outputting 7,55v.
the other is a 14,4v Ni-Cd outputting 11,86v.
but i don't have a charger for any of them.
i have a variable power supply and i was wondering if i could use that to charge them.
if it's possible: at what voltage do i charge them and is there anything i need to watch out for?
Solidacid
EDIT:
i completely forgot, i also have a battery pulled out of a completly destroyed roomba, it's 14,4v 2500mAh and it outputs 2.79v and is made up of 12 cells. any suggestions?
Fri Apr 03 2009, 05:10PM
similar cells and chemistry *should* work, but be careful. If its NiMH then you *must* use the same cells or the charge circuit could fail causing the cells to vent or worse.
BTW I wouldn't solder to the cells, can block the safety vent and also weakens the seak causing cell failure after about three months or less. Use the tabs if possible.
regards, -A
Solidacid
Fri Apr 03 2009, 08:45PM
Conundrum wrote ...
regards, -A
What?
these are assembled cells taken from cordless drills. im not going to use them together or anything, just charge them one at a time.
Fri Apr 03 2009, 09:10PM
For manual charging NiCd,NiMH,Li etc
A current-limited constant-voltage charging scheme is quite good.
0.1C or C/10 is safe for all common storage batteries.
e.g. Charge 2500 mAh cell/battery at 250 mA for more than 10 hours from flat.
Do this with current-limit on a psu
or just a resistor to limit maximum charging current.
Lithium are the simplest, NiCd should stop charging when the charging voltage 'dips' for a while (c20mV), if not then when the cell(s) feel warm.
Batteries are always best charged as individual cells.
There are all kinds of charging schemes - google for millions of results !
I have come across many failed cheap battery packs
often just one bad cell, sometimes the internal thermal fuse,
unfortunately though, most manufacturers use really cheap/nasty cells
that may give you a false impression of the potential of good rechargeable batteries.
