  • Guests: 38
Sanchez (36)
Knarvel (13)
10/16 Sanchez (36)
10/16 Knarvel (13)
LCD computer monitor repair help
Zum Beispiel
Thu Apr 02 2009, 10:25PM Print
I wasn't quite sure where to put this, so feel free to move it.
I dug a LCD monitor out of the trash the other day. It's a IBM ThinkVision L171 17" display, manufactured in 2005. Upon pluggin it in I was surprised to see it show the IBM logo and then "No Input signal." Everything is looking good.
However, when connected to a computer, upon start up it shows a few lines of text, the usual things you see when a computer is booting up but, after a second or so, it turns into a jumbled mess. This happens when more stuff starts coming on the screen. The display goes black (the backlight is still on), then the random mess comes back for a second and then the screen goes back to black. This cycle repeats over and over and seems random. You can still make out letters or even lines of text from the mess, though.
The power supply board had a load of bulged and/or leaky caps, which I replaced (I re-capped the whole board) hoping to fix the problem, but it didn't help. There are no other obvious signs of damage. The 12V output reads 12.5V and the 5V output 5.1V.
I realize the display is probably done for, but If anyone has any ideas, I'd love to hear them. My current CRT monitor is a POS and I'd really like to replace it with a LCD display (But I'm not going to go out and buy one cheesey).
Soo, any ideas?
Chris Cristini
Fri Apr 03 2009, 02:13AM
That sounds like refresh rate take a monitor that will work on the computer you are using and lower all of the resolution and refresh rate if this does not work I don,t know
Fri Apr 03 2009, 07:30AM
If it takes 12V and 5V, try running it off a different power supply. Wire it up to your computer's 12v and 5v rails or whatever.
If this fixes the problem, you know the fault is in the power supply. If it doesn't, you know the fault is in the mainboard, or the horrid flexi-chip thing in the LCD.
I doubt refresh rate would be a problem, a 2005 monitor will have DDC, so it can tell your OS what refresh rate and resolution it wants. Unless you're running some old Linux that doesn't support it.
Oh, also check the VGA socket/cable to make sure all the contacts are good.
Sat Apr 11 2009, 07:37PM
could be dodgy caps...
-A
Steve Maurer
Sun Apr 19 2009, 01:22PM
Steve Maurer Registered Member #133 Joined: Fri Feb 10 2006, 10:27PM
Intermittent problems are tricky, but it could be a broken solder joint on the board assembly. This frequently occurs in electronic equipment due to normal thermal expansion / contraction during use. Look for hairline cracks in the solder around component leads. As solder cracks are hard to find, a magnifier is definitely helpful for the task.
A can of freeze spray is helpful in pinpointing broken solder joints. Use the freeze spray on small sections of the board until the problem appears / disappears with the application of the spray. Subsequently look for solder problems in the vicinity of the area that was sprayed.
You may also locate solder cracks by lightly tapping on the board with an insulator while the board is running. The back of the insulated handle of a screwdriver works well for this.
The last method to correct for poor solder joints is to re-solder complete sections of the board until the problem disappears. Pick a section of the board, re-solder it, and then turn on and check the device. If the problem still exists, then go to the next section and re-solder it. This should be used as a last resort, as it is obviously tedious.
Regards,
Steve
Zum Beispiel
Sun Apr 19 2009, 04:01PM
Thanks for all the input. I recapped the whole powersupply board, that had bulged caps, but that didn't help. I also went through the solder joints and resoldered some of the more dodgy joints, but no change.
The bad caps probably made the PSU give out a higher voltage than was intented, and that damaged the more sensitive electronics. So in short, I think the display is done for.
Oh well, it was worth a shot.
Sun Apr 19 2009, 04:31PM
When I was something like 12 I repaired a TV by taking a soldering gun and reflowing all of the solder joints. Turned it on and it worked. Something to try when you have nothing to do :)
