  • Guests: 55
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
Monitoring voltage of 15kv pulse cap?
hotcrazyfruit
Tue Mar 24 2009, 02:26AM Print
hotcrazyfruit banned on 5/26/2009
Registered Member #1877 Joined: Mon Dec 22 2008, 02:03AM
I recently bought a 15 KV * 225 uf pulse rated capacitor from Link2 (prime only, no finish) , rectification wont be a problem. i have 1000, 1 amp diodes that are rated for 1000 volts each. I plan on charging it with 4 parralell NST's at 15kv. the only problem i can think of facing is telling when its charged. other than that it will stop drawing current, i want to know if it is getting to the desired voltage. any help is greatly appreciated.
Nick,
P.S.
ill be using it for coilguns/railgun and destroying stuff :)
Backyard Skunkworks
Tue Mar 24 2009, 02:48AM
Why not just build a massive resistive voltage divider and monitor it with a DMM?
You just need to be careful that each resistor has very little current through it and is well below its arc over voltage.
hotcrazyfruit
Tue Mar 24 2009, 02:59AM
Backyard Skunkworks wrote ...
do you have a schematic for one? or a place to find one? thanks :)
aonomus
Tue Mar 24 2009, 03:12AM
Resistive dividers don't behave well with AC iirc, you have to add compensating capacitors?
rp181
Tue Mar 24 2009, 03:14AM
A resistive voltage divider is the most basic of principles. All it consists of is 2 resistor's in series, with a resistance ratio.
Keep in mind what backyard said. Get some high voltage resistors, and keep the resistance high. If it draws too much current, they could easily fail and cause a catastrophic event.
I hope you understand the danger of that high energy, not to mention that high energy at that high voltage. Have you ever used a smaller bank? Take it slow, and don't charge to 15kV for your first charge.
EDIT: Why would AC be a problem? Its being rectified. If I get what you mean, they i second the compensating capacitors.
EDIT EDIT: noticed the link you posted. Sorry about that =)
Backyard Skunkworks
Tue Mar 24 2009, 03:17AM
aonomus wrote ...
Interesting point. But the cap is obviously not seeing AC. He'll be monitoring (from a large distance) DC voltage across the cap after the rectification diodes.
hotcrazyfruit
Tue Mar 24 2009, 03:35AM
ok thanks
rp- iv got a 5 kilojoule bank of the same caps you've got.(except 16 instead of 18) i made the 400v boost converter. worked perfectly. got some good shots off with a coil gun. never made a rail gun . thinking about a mortar cannon. but i got bored of that bank. so instead of 5 KJ i wanted something bigger xD like say 20KJ ?? . and yes i do understand the risks and dangers :) i hadent made or ever had the need to use a resistive voltage divider before (at least for monitoring voltage) . thanks all.
Nick,
Tue Mar 24 2009, 12:24PM
I suggest a 1G resistor in series with 1M1. With a 10M DMM, the voltage across the 1M1, will represent 1000:1 across the whole series i.e. 15kV will read as 15V.
If you have no 1G resistor of suitable voltage and wattage, you could solder 100 * 10M resistors etc in series. Wind the resistors round a plastic rod, and submerge in a tube of oil.
Most TV service EHT probes use a 1000:1 voltage divider.
aonomus
Tue Mar 24 2009, 02:19PM
Sorry, are you trying to monitor charging voltage, or are you trying to capture the discharge waveform? I may have read the wrong thing...
If you are just trying to monitor charging voltage, resistive divider works, but if you are trying to view discharge on a scope and capture I don't think it will work too well....
hvguy
Tue Mar 24 2009, 08:31PM
hvguy Registered Member #289 Joined: Mon Mar 06 2006, 10:45AM
If you can afford one of those caps chances are you can save yourself the hassle and just buy on of these Link2 off of ebay. I use them all the time for monitoring caps up to 100kv (more than twice the rating, NOT recommended!)
