  • Guests: 58
Why doesn't this work? (self-oscillating circuit)
Sat Apr 11 2009, 11:09AM Print
I think you all know the "single transistor flyback driver" which produces more heat than output.
Based on the topology, I wanted to create an efficient Class-E (or at least near class-e) driver for the TV transformer. This is the circuit I came up with, note that the resonant capacitor is not shown as it killed the operation completely (see later):
1239448218 152 FT67392 Trafo
With the circuit as shown, I tried both polarities of the feedback winding. In one polarity it just shorted the supply, in the other one nasty HF oscillations started appearing and the gate driver heated up (gate signal was anything else but square wave; there was no visible output from the xfmr). When I tried to add the resonant cap, the oscillation stopped completely.
Any ideas?
Hon1nbo
Sat Apr 11 2009, 02:26PM
reason why one polarity of feedback shorts your powersupply, and forgive me if any of this is inaccurate, is that it must be coordinated with your primary - after current conducts via the feedback into the transistor stage, which turns on the primary, then it must be designed such that the current induced in the feedback from the primary must oppose the normal current flow, therefore shutting off the transistor, so if you improperly connect it it would keep the transistor on at all times, and current is being increased rather that being decreased... but again, what I stated might be wrong (I've only messed with the design from Powerlabs using a 2N3055, which I used for a lot of things just fine)... however, like you stated they more or less produce heat that output : - P
but also, is there anything else connected to that TC4422 Mosfet Driver? according the datasheet, it has it's own Vin, etc... I dunno if you just left that out of the schematic, but maybe something there is going on
it also seems that the frequencies used in the graphs on the TC4422 datasheet indicate a higher frequency that what I thought flybacks operate at... at least efficiently, maybe that is causing issues with the HF oscillations, but i'm not sure at the moment, am in a rush to get out of the house so this is just to toss a few things out there? - it can be found HERE
MRacerxdl
Sat Apr 11 2009, 02:56PM
I did a similiar thing once, but I figured out that a startup oscillator helps, Here are my Cold Cathode Fluorescent Lamp Inverter Schematic:
Sat Apr 11 2009, 03:08PM
>DaJJHman: I know that only one polarity will work. But the problem is that the oscillations are in the MHz range and there is absolutely no output from the transformer.
And yes, the supply rails for the TC driver are omitted and of course connected, to +15V.
P.S. The windings should actually be polarised the other way so that the feedback is positive, when the transistor turns on it causes even more current to the base, holding it ON for a while, until the core saturates and the base current falls so low that it's no longer able to hold the ramping collector current, then a flyback pulse happens which is seen with negative polarity on the base, holding the transistor OFF during the flyback pulse.
Kolas
Sat Apr 11 2009, 10:48PM
Kolas Registered Member #102 Joined: Thu Feb 09 2006, 08:15PM
I don't know, it almost seems like you'd need to be using inverting logic for it to set up real oscillations.
Sun Apr 12 2009, 11:00AM
Kolas wrote ...
But I can invert the feedback... ?
I think the fact that it works with bipolar transistors is because of their very nature and electrical characteristics, as they must de-saturate just before the flyback pulse happens. The gain of my circuit is practically infinite so this can not work...
Sun Apr 12 2009, 11:44AM
Have you calculated what the frequency of oscillation should be, lad?
Sun Apr 12 2009, 11:57AM
Harry wrote ...
In the original circuit it is probably mostly determined by the transistor de-saturating, or by the base current falling too low, probably a combination of both. The OFF period lasts as long as feedback voltage does not fall back to cause conduction of the transistor.
In any case, the voltage on the FB winding cannot reverse while the transistor is ON, so this is the reason why it can never turn off with my circuit.
