  • Guests: 34
09/13 WarrenR (64)
09/13 currentkills91 (32)
09/14 Proud Mary (62)
LED
Danielle
Sat Mar 21 2009, 11:01PM Print
1237676493 632 FT0 Led Small 01
1237676493 632 FT0 Led Small 02
1237676493 632 FT0 Led Small 03
1237676493 632 FT0 Led Small 04
1237676493 632 FT0 Led Small 05
1237676493 632 FT0 Led Small 06
1237676493 632 FT0 Led Small 07
MRacerxdl
Sun Mar 22 2009, 03:26AM
Hmm, very good work =)
But can you post more details, like what exact is it?
Audio RGB Led Controller?
teslacoolguy
Sun Mar 22 2009, 04:11AM
very nice....i like the clear plexi case. What is that led on the giant heatsink for? It looks like a 1w luxon rgb with only 1 color connected. Here i thought girls wern't into electronics and tesla coils wink
Download
Sun Mar 22 2009, 11:30AM
Download Registered Member #561 Joined: Sat Mar 03 2007, 02:46AM
What is it?
Danielle
Sun Mar 22 2009, 08:01PM
I am planning on patenting this so until then I caint give details.....sorry
and those are luxon LEDs but the module is a total of 12W cheesey
rp181
Sun Mar 22 2009, 08:51PM
was there text that you removed? I could have swore i read what it does...
Anyways, nice job for what ever it is. If heating becomes a problem, its probably not good to put a heatsink in a enclosed space.
Good luck with the patent.
Danielle
Sun Mar 22 2009, 11:05PM
Thanks, and yes I did have the description, but I removed it just in case. The heatsink in the pic is overkill and wont be what is used in the final design, I just had it on hand and it looked nice.
Mon Mar 23 2009, 12:35AM
Looks like a UV dental inspection device.
Mon Mar 23 2009, 11:14AM
I think you'll find our Dr. Spark already has the patent on things made out of LEDs and plexiglass.
And Philips probably have the patents on every other application of LEDs. For example, they actually patented the idea of mixing more than two colours of LED light. If you want to sell a RGB LED light commercially, you have to take out a license from them! So if you're going to apply for a patent, check the prior art real carefully.
GeordieBoy
Mon Mar 23 2009, 12:18PM
Ahhh, so that explains why those Philips moodlight things are so ridiculously expensive!
