  • Guests: 28
09/13 WarrenR (64)
09/13 currentkills91 (32)
09/14 Proud Mary (62)
Pop can TC
semiconductor
Tue Mar 24 2009, 06:42PM Print
semiconductor Registered Member #1989 Joined: Fri Feb 20 2009, 05:28AM
This is a small TC I made in a few hours on a sunday afternoon. I all started with the toriod I made from the bottoms of two pop cans I cut apart and stuck together. After that I had to make a coil for it!
Some of the specs:
Primary, 6 turns of #16 on a 4" pvc form
Secondary, Aprox 800 turns of very fine wire from a bath fan motor on a 2" x 3" form.
Tank cap, One 20Kv 1400pF ceramic doorknob capacitor
Power supply, 6Kv 30mA NST
Torroid, Two pop can bottoms put together and pollished.
The secondary has quite a few coats of polyurathane but still throws off corona around the top windings, and even gets the odd primary strike. To finish the ends of the secondary I plugged the end with a piece of plastic about 1/2" in and attach a nut and bolt to the wire and then fill in the end with epoxy. This makes a strong connecting point for small coils.
Pics of the coil
Tank cap and spark gap.
Some sparks.
Arcs to an ungrounded object.
Tue Mar 24 2009, 07:23PM
wow that coil is awesome amazed Although from what i understand your sparks are usually supposed to be longer than the transformer is wink But considering how high of a frequiency your are running for such a crappy spark gap that isnt half bad!
I really like your torroid, although judgingby your issues with corona at the top it isn't working to great. But hey if it works it works
rp181
Tue Mar 24 2009, 07:49PM
That is really cool, it would make a nice desktop though abit loud. How did you get the pop can toroid so smooth and seamless?
Nice job.
Tue Mar 24 2009, 07:54PM
That's really cute .. I like it a lot.
CT2
Wed Mar 25 2009, 02:32AM
CT2 Registered Member #180 Joined: Thu Feb 16 2006, 02:12AM
How to make the toroid: Link2
I like the coil, so compact its all on the NST haha!
hotcrazyfruit
Wed Mar 25 2009, 02:38AM
hotcrazyfruit banned on 5/26/2009
Registered Member #1877 Joined: Mon Dec 22 2008, 02:03AM
I have the same NST as you, only white box. nice coil. dont you just love the smell of ozone on a sunday? lol. i took that quote from somewhere. forget xD
Killa-X
Fri Mar 27 2009, 07:07PM
While eating some good candy, it made me ask.. Can an Altoids tin actually work too? the bottom larger half is smooth on the outside..I mean.. If you have one why not try? My mosfets are shot at the moment else I would :(
