  • Guests: 60
  • Most ever online: 441
    Guests: 441, Members: 0 on 01 Oct : 16:32
GhostlyFigures (36)
10/06 Ivan Kalafatic (17)
10/07 Pyromaniac (34)
10/07 Wavetuner (76)
Mazilli flyback driver as a step down?
Firnagzen
Sat Mar 21 2009, 05:24AM Print
Firnagzen Registered Member #567 Joined: Tue Mar 06 2007, 10:55AM
I was thinking it would be nice to have a high power power supply, but I don't feel like shelling out a lot or getting a huge clunky transformer, and while mulling over it, I wondered: would it be possible to use a Mazilli flyback driver as a high frequency transformer driver? Rectify the mains, hook up the driver using 1200V IGBTs (I suppose I'd need something clever to stop the zeners on the gates from burning out.) and use a high frequency transformer.
But then, I'm relatively new to this. Would it work?
Ps. What kind of a core size am I going to need for 1.5kW?
aonomus
Sat Mar 21 2009, 05:51AM
What is the intended purpose and target voltage range/current?
The easiest thing that comes to mind would be using a MOT with a re-wound secondary for low voltage, high current. This only works if you have a AC source, if you need a DC-DC stepdown then that is a different story...
Firnagzen
Sat Mar 21 2009, 05:58AM
Yes, it's from the wall to about 40 volts. Problem is, I don't have a MOT, and I can't get one easily, either. (I live in Singapore. Junkyards are notably absent.)
Sat Mar 21 2009, 10:15AM
I say don't bother, if you try, it'll most likely end up as an explosive expereince.
Littlew
Sat Mar 21 2009, 01:03PM
Littlew Registered Member #1448 Joined: Sat Apr 19 2008, 01:16PM
i used zvs driver to step down from 48v to 12v
but zvs driver works bad on 220v(or 110v) even with igbts.
You can make half bridge or full bridge. Or try to rewound solid state MOT
Firnagzen
Sun Mar 22 2009, 05:29AM
Mmm. Why explosive? And thanks, for the replies, all.
Sun Mar 22 2009, 08:17AM
Firnagzen wrote ...
Well, if you want to talk about that...
The gate drive in this circuit is imperfect, spurious oscillations of high frequency can happen within this gate drive scheme. I've found that increasing voltage increases the possibility of these oscillations, possibly because the gate voltages fall quicker. Also, smaller gate resistors seem to increase the possibility of these oscillations.
When powering it from rectified mains, you'll need to use a small step-down transformer to power the gates. Now, selecting the gate resistor value is very important because too big resistors decrease efficiency and possibly break the feedback loop, stopping the oscillation and resulting in failure. On the other hand, as I said earlier, too small resistors result in unwanted high-frequency oscillations, which damage the transistors.
I really would not be surprised if "too small" and "too large" for the gate resistors overlap by a great margin when running the circuit from mains, meaning that proper selection of the resistors is impossible and the circuit will never run reliably.
Another thing is that during the switching transition, the current may be interrupted for a moment and the series choke could spike above 1200 volts destroying your transistors. Also, improper selection and design of the choke may result in the collector (drain) peak voltages to reach higher values than they would normally do, again damaging your transistors.
Finally, from principle this circuit stores a great amount of energy in the core and resonant cap, meaning that the core and primary winding will run MUCH hotter than with a half-bridge drive.
This circuit seems to be benefical only when driving a highly reactive load, such as drawing arcs, but for a voltage power supply, a bridge is a wiser choice.
Edit: This is especially for running it from rectified 230V mains, for 120V it might be "slightly more doable" but still.
Firnagzen
Sun Mar 22 2009, 09:02AM
I see. What, then, would be the easiest* way, then, other than a big transformer, to get a nice high current power supply? A full blown SMPS? I'm not too concerned about regulation.
*I do realize that it won't be easy by any stretch, but eh.
Thought: I wonder if the high frequency oscillations are preventable.
Sun Mar 22 2009, 09:44AM
Firnagzen wrote ...
Well, if you don't need high output voltage regulation, then it can be as simple as a half-bridge (like in SSTC with no PWM), transformer, rectifier and filter capacitor.
Firnagzen wrote ...
I've had some success with active feedback (w/ gate drivers), which ran quite smoothly at ~70V DC, but it blew an IGBT anyway and I gave up that circuit. It's good if you want to get quick big arcs easy out of a TV transformer, but for not much else.
Firnagzen
Wed Mar 25 2009, 04:50AM
Hm. Do those CCFL circuits work with FETs, or IGBTs?
I realize that first of all, I'm going to have to get the voltage down to about 10V to prevent the gates from burning out. But is there anything else?
