  • Guests: 29
09/13 WarrenR (64)
09/13 currentkills91 (32)
09/14 Proud Mary (62)
Solid state tesla coil based off Richie Burnette's
Doubl3 Helix
Sat Mar 21 2009, 04:40AM Print
Doubl3 Helix Registered Member #1548 Joined: Mon Jun 16 2008, 09:22PM
Hello all.
I have created a SSTC based heavily off Richie Burnett's SSTC...well, it's pretty much the same thing. But for a first coil, why not try to copy another persons design, right? cheesey
But anyway, here are my specs:
Circuitry:
  • Same drive circuitry
  • Same full-bridge design but with 20N50T MOSFETs
  • 140VAC -> Fullwave rectified
Primary:
  • 5 inch OD
  • 8 turns of solid 14 AWG wire
  • Cardboard form
Secondary:
  • 4.25 inch OD PVC pipe
  • Approx. 27 inches of 24 AWG winding
  • Around 25 coats of polyurethane varnish
Topload:
  • Toroid with 3 inch minor and 11 inch major diameter
  • Breakout point straight up from center
For my ground I used a copper pipe pounded about 5 feet into the earth, attached to it is a 50 foot 14 AWG grounding wire that runs to my lab area.
Overviewe
This is a picture of my coil pretty much done. You can see the old 10 AWG primary in the background.
Bridge
Here is a close up shot of my bridge.
Cimg0839q
In this picture, there are about 5-6 inch streamers from an insanely small toroid.
Streamers
Here is a picture of streamers after a new, smaller primary, as well as a properly sized toroid.
Arc length in this pic is about 7 or 8 inches
Since the last pictures were taken, I decided I would decrease primary turns in attempt to increase arc length.
I hit about 11 to 12 inch streamers, and this is when things started to go wrong...
First, the resistors that the bridge V+ goes through to sweep the freq. down began to smoke and burn when it was connected. Fortunately nothing else was harmed, and I just disconnected this. Arc length maintained in the same ball park, but performance may have been deteriorated somewhat. Any likely causes of this? Maybe just shoddy resistors? angry
Then when I hit 7 turns, I had the coil running at max 140 Vin, and after about a minute or minute and a half, the 7A fuse blew. I replaced the fuse and slowly turned the variac up. The fuse blew again at 14 Vin. I go in with my multimeter and find that two FETs on the same side have their drain and source at a dead short. They are not removed from the circuit, but it really should not matter(on the other side, the FETs drain-source resistance is about 525 ohms). There is no physical damage to any parts, so that is probably a plus. Could this be from the FETs pumping to many amps and not sufficient heatsinking? I have no thermal grease on the FETs, just screwed to the heatsink...very poor thermal conductivity. Perhaps someone more experienced on this matter could point me in the right direction? Would it be a good idea to just add a turn to my primary, replace the FETs, and go at it again? Or could there be an underlying problem? Any thoughts would be greatly appreciated, and feel free to ask questions.
Again, this is my first coil, I know its not the greatest...but it's something! wink
kilovolt
Sat Mar 21 2009, 07:45AM
kilovolt Registered Member #2018 Joined: Tue Mar 10 2009, 09:56AM
Nice coil and nice arcs!
The problems of the dead bridge may be caused by a bad gate signal quality. If the MOSFETs don't turn on and off fast enough, they will die. This is due to switching losses. I would check the signals on the gates of the power FETs with a scope. Turn-on time should be 200ns or better from my experience.
EDIT: Another thing: Your secondary may not have a good aspect ratio (it is very tall if you compare with its diameter. Normally the ratio of height to diameter is not more than about 3:1.
Greets kilovolt wink
Sat Mar 21 2009, 05:25PM
Nice coil!
Ah yes, you also want to make sure you are not getting too MUCH gate drive. If the mosfets are not made for the freq you are using, the gates require more current to switch so fast, and they could get damaged/melted. I am sure this is not the problem, but i felt i should throw it out there.
That reminds me i need to check my gate drive signal, as i have a new true RMS volt meter. Sweeeeet.
