  • Guests: 58
Writing with sparks (neatly)
Tesladownunder
Fri Mar 20 2009, 05:21PM Print
Anyone want to have a guess how I did this?
1237569664 10 FT0 Pantesladownundersparksonly
KLH
Fri Mar 20 2009, 05:54PM
Here are a few guesses:
1. PHOTOSHOP!!!
2. 1000 flyback arcs
3. Little nodes on a board with HV run through them spaced to form the arcs shown
Fri Mar 20 2009, 06:09PM
Judging from the angle of the sparks, it seems to be a kind of a rotating electrode/breakout point, but I'm not sure how exactly it's done.
Tesladownunder
Fri Mar 20 2009, 06:11PM
I don't use photoshop on principle.
Not 1000 flybacks and nothing is rotating.
It is a cropped 175 second photographic exposure. I can change fonts as needed. That was bold 280 point Impact font.
Sparks are generated by my dual ignition coil setup driven by SIDACs and a MOT.
Any other ideas?
Fri Mar 20 2009, 06:39PM
The spark length and direction is constant so you are using some kind of guide and slowly tracing the letters with a fork-shaped stick. Where 1 prong is your HV and the other is the return.
Tesladownunder
Fri Mar 20 2009, 06:44PM
Closer. But how could I see to trace something in darkness sufficient to not show up on a 3 minute exposure?
This is a demonstration of how it is easier to work out how something is done than to do it in the first place.
big5824
Fri Mar 20 2009, 06:51PM
you just cut out that shape in paper and moved the arc behind it?
Myke
Fri Mar 20 2009, 06:55PM
Something that can move the arc gap in the x and y coordinates with steppers or servos I guess. You programmed a controller to move it in that way to make the letters. Maybe?
One think I am wondering is about is why the arc changes angle. Is it because the camera is on the left side of the display thing and the gap is vertical?
Tesladownunder
Fri Mar 20 2009, 06:57PM
Myke wrote ...
A plotter is far too clever for me at my age although I did do one about 30 years ago for the Vic 20 computer. Article is here.
Good observation about the angle. Gap is horizontal.
The answer is simple as I was under some time pressure.
Not sure how cutouts would work and don't think you are seeing a cutout shape in silhouette here.
This was developed in response to a request for a logo in sparks by VICE TV. Will be filming it later today.
Other thoughts?
Mattski
Fri Mar 20 2009, 07:13PM
I'm going to guess...
You drilled a bunch of little holes in thick acrylic for each letter, put a ground plane beneath, and put chicken wire (or another grid) of HV on top and let it run.
Or, you cut each letter out of acrylic to use as a guide, pasted them on top of a ground plane, and moved a stick with HV around each one, turning off the HV between each letter.
wrote ...
I need to read better, that pretty much throws out these guesses.
Next guess: you were in a different room with lighting, tracing out these letters with a stick that passed into the dark room with the camera.
