  • Guests: 55
Capacitor discharge limit
woxxey
Wed Mar 18 2009, 10:17AM Print
woxxey Registered Member #1906 Joined: Sat Jan 03 2009, 05:06PM
I was wondering if there is something like a discharge current limit for capacitors? So if they are discharged to fast they will blow up or something.
I read something about max. ripple current, but I dont quite understand what it is?
aonomus
Wed Mar 18 2009, 12:49PM
Maximum discharge current is limited by a couple factors:
- Internal resistance (also known as equivalent series resistance) due to the materials used in construction and more importantly the inductance caused by the windings of the plates in electrolytics.
- Terminal to plate connections also limit the max discharge current in extreme situations (ie: pulse discharge for what we do). Magnetic forces from high discharge currents could potentially tear the plates from the terminals (or so I've been warned before).
- Insufficient terminal sizes may simply burn out with a varying degree of kaboom.
Wed Mar 18 2009, 01:12PM
To add to Aonomous' good advice, pulse power capacitors will always have peak repetitive current and surge current maximum ratings in their data sheets.
aonomus
Wed Mar 18 2009, 01:41PM
Don't forget to consider the pulse discharge length through your load, the shorter the discharge time, the greater the current will tend to be and as a result, more strain on the capacitor. Most industrial inverter or pulse grade lytics have ratings based on 60hz (8.32ms) or 50hz (?), but some have a logarithmic plot of frequency and ratings.
