  • Guests: 24
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
Transformer question
StevenCaton
Mon Mar 16 2009, 12:08AM Print
StevenCaton Registered Member #1845 Joined: Fri Dec 05 2008, 05:38AM
I have quick question about transformers.
Normally a MOT is fed 117VAC and gives 2100VAC on the secondary. (with a peak value of 3000V on the secondary)
If I fed an MOT pulsed DC Half wave (directly out of a full bridge rectifier) (117VAC input) would this work, and provide 3000V peaks on the secondary.
the_anomaly
Mon Mar 16 2009, 02:43AM
the_anomaly Registered Member #19 Joined: Thu Feb 02 2006, 03:19PM
I think you will just saturate the core. I belive the other half of the cycle is needed to first unmagnetize and then reverse the magnetic field of the core.
rp181
Mon Mar 16 2009, 12:21PM
I tried it a while back. The core does saturate, and you need a half-wave (1 diode) rectifier for a halfwave ouit.
KLH
Mon Mar 16 2009, 06:01PM
The core WILL saturate within a few cycles. Transformers (except ones that are meant to store energy) are meant to be driven with equal volt-seconds for each half of the cycle. If the magnetic path is closed and there is a miniscule DC component in the drive signal, then the flux will eventually "walk" into saturation. Of course, small imperfections in E core construction (gaps) and winding resistance will allow these transformers to tolerate a little DC offset. Toroids, however, are absolutely intolerant of DC offset if it is not controlled by winding resistance. If you really need to use this type of drive waveform, then you might be able to wind a reset winding onto the transformer, like in a forward topology transformer. This does reduce core utilization, which in turn reduces max power output.
Mon Mar 16 2009, 06:45PM
Just to add to the above;
- ANY dc in the primary will reduce available output
- In practice if you put a half- or full-wave rectifier before the primary you will blow a fuse/breaker in under a second !
More importantly,
- No matter what waveform you put into the primary,
the secondary output voltage MUST have an average output of 0 volts,
the area under the volts vs. time for the positive part of the waveform WILL/MUST equal the area under the volts vs. time for the negative part of the waveform.
In short - there is no way you can do better than ac in / ac out,
unless you can shorten the time of each half-cycle,
e.g. operate at a higher frequency or short pulse-width.
Neither of which are of much benefit when you only have normal ac supply.
In theory you could put a triac-type phase-angle controller (light dimmer etc.)
before the primary and operate on 230 Vac for example,
but as soon as you get too 'brave' something will 'pop'
If you need higher dc output voltage you could use a Greinacher (Cockroft-Walton) voltage multiplier.
StevenCaton
Mon Mar 16 2009, 06:53PM
Thanks for clearing that up for me guys.
Mon Mar 16 2009, 08:23PM
Sulaiman wrote ...
Actually, I believe this is true only for the primary waveform, we all know that it is perfectly possible to drive halfwave rectified TV transformers from a bridge and draw arcs from them (which is basically a short circuit for every other halfwave on the secondary).
KLH
Mon Mar 16 2009, 09:55PM
Dr. Kilovolt wrote ...
Sulaiman wrote ...
The transformers you are referring to are flyback transformers. These store energy, and so are designed to support some DC magnetizing force in their air gap / gaps. The volt-seconds for ALL waveforms / windings must average zero in the core for transformers not designed to store energy, or the flux will saturate.
Mon Mar 16 2009, 10:09PM
killah573 wrote ...
Sulaiman wrote ...
I thought that too, until I removed the air gap and it worked still! I heard some sub-harmonic resonances though, but the performance didn't seemed to be hurt much. However this was a long time ago and some details are a bit "blurry"...
KLH
Wed Mar 18 2009, 10:07PM
killah573 wrote ...
Sulaiman wrote ...
Tunnels on 4HV? Let the fun begin.
Anyway, all transformers store some (usually undesired) energy. I'm thinking you were using either an E-core or a U-core set, since these tend to store more energy. I don't believe that this would be possible with ferrite toroidal cores, because these have very low leakage inductance.
