  • Guests: 51
Ash Small (63)
Oatmeal (38)
01/06 Ash Small (63)
01/06 Oatmeal (38)
01/08 Lyonel Baum (77)
Dekatron Spinner
Myke
Sat Mar 14 2009, 04:13AM Print
Hi.
I decided to make a dekatron spinner for the fun of it.
A dekatron spinner is a display thing that makes the glowing gas in the tube to move in a circular path. It does this by applying pulses to the glow transfer guides causing the glow to move from one cathode to another.
I used the 6802 for my dekatron spinner and for the anode supply, I used a four stage voltage multiplier.
1237004011 540 FT0 Img 3784
I made a little stand thing to connect all the cathodes together. I made the copper ring at the bottom by wrapping some 14 awg wire around a wooden dowel then flattening it with a vice. I forgot that I needed to do that after mounting the socket. :S It's fine for now though.
1237004011 540 FT0 Img 4264
I used a couple resistors and capacitors for shifting the phase angle to drive the guides. The problem was that the original phase shifter (that's what I call it) didn't work properly. I scoped the output of it and found that for some reason, both the signals were in phase (or just out of phase by a little bit).
1237004011 540 FT0 Img 4265
I found another diagram that had a different layout and I tried that. The design itself wasn't that different so I just lashed up the phase shifter.
1237004011 540 FT0 Img 4269
The other phase shifter worked well so I am going to use that for my final design.
1237004011 540 FT0 Img 4272
Here is a video of the spinner running. Sorry about the quality of it :S. Link2
Later, after I mess around with it more, I'm going to put the entire thing in a plastic case because it won't be isolated from mains. Also I am going to have multiple switches that can switch if it is spinning or frozen, the direction, send a pulse to the guides when it's frozen, switch the rate that the guides receive a pulse.
I am thinking of making a ring counter out of discrete parts to divide the mains freq. I could either use neons or transistors. There are problems with using neons to divide the line freq. There need to be buffers between the multiple rings, it may be unreliable and also it's kinda difficult to obtain the neons that have a large enough difference between striking and maintaining voltage. I guess I'll go with transistors then. Is there any other way to divide the mains freq easily with discrete parts?
coillah
Sat Mar 14 2009, 09:26AM
coillah Registered Member #1517 Joined: Wed Jun 04 2008, 06:55AM
The thing in the glass tube that's an actual part? Where did you get it?
You were just building the control system for it?
Whatever it is, it looks cool!
Sat Mar 14 2009, 11:48AM
coillah wrote ...
Yep, it is a 6802 electron tube/vacuum tube/thermionic valve/valve. (wiki: Link2
Looks kewl Myke I love it :) Now I'm at it.. You don't have any schematics do you? :p
Myke
Sun Mar 15 2009, 12:03AM
I just got the dekatron from ebay. Yeah, the 'control system' applies ~500V to the anode and pulses that are out of phase to move the glow from cathode to cathode.
I used something similar to this schematic. Link2
The values of the caps aren't too critical. I used .22uF caps for the multiplier and a .1uF cap for the phase shifter. In some diagrams they call for a 33k resistor in series with the multiplier but I found that was too much for 120V operation. I used 1.8k and it works fine.
Here is some data for the 6802 dekatron. Link2
