  • Guests: 40
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
Leaders LBO-524 oscillosccope problems
iRET
Tue Mar 10 2009, 03:41PM Print
iRET Registered Member #258 Joined: Sun Feb 26 2006, 03:58PM
Hi All,
I am getting weird square waveform from my oscilloscope channel 2. It is curved on the top instead of the typical square wave, what could be the issue ?
Tue Mar 10 2009, 04:19PM
Check the easiest first, swap Ch.1 and Ch.2 probes.
'scope probes seem to be a consumable item
always check your probes when any experimental result seems 'wrong'
GeordieBoy
Tue Mar 10 2009, 06:39PM
What is the frequency of the sq wave you are measuring? It might be that your probes are not compensated correctly.
iRET
Wed Mar 11 2009, 04:14PM
Did tried swapping channel 1 probe and also clean the rotary switch contact, still the same though...
Btw, I have been trying to upload my scope shot photo since yesterday, but kept ending up with a blank screen. Anybody having the same problem ?
Bamacoiler
Wed Mar 11 2009, 06:56PM
Bamacoiler Registered Member #1628 Joined: Wed Aug 06 2008, 08:48PM
I'm assuming your measuring a square wave and getting a curved top. If your probe has an adjustment, try tweaking it until the square wave is square. if I'm wrong and it's not that simple, sorry.
Tom540
Wed Mar 11 2009, 08:00PM
Tom540 Banned on 3/17/2009.
How about connecting the probe to the calibration pin on the scope then adjusting the scopes variable cap instead of just assuming the waveform you're measuring is super clean? After that then see if the one youre measuring look better.
iRET
Thu Mar 12 2009, 01:44AM
Yes, I am measuring square wave and both probes are connected to the calibration pin which generates square waveform. Also, tested the probes capacitance adjustment, didn't work at all. Could a faulty power supply capacitors causes such curve during the square wave rise? I did noticed two of the power caps kinda mouldy when I first got them. The waveform actually looks like those Mosfet output driven with too much gate resistance.
Bamacoiler
Thu Mar 12 2009, 01:17PM
I would say that if you can't adjust the overcompensation down then your probe is probably hosed.
GeordieBoy
Thu Mar 12 2009, 02:36PM
some pictures would surely help
iRET
Sat Mar 14 2009, 02:45PM
Finally!
1237041912 258 FT65358 Scope S
