  • Guests: 50
Skywarrior (52)
Dark Horse (54)
LD LANGER (38)
12/19 kywalda (63)
12/20 plazmatron (48)
12/20 rm203tech (17)
Chaos circuit
G^3
Sun Mar 08 2009, 10:46PM Print
G^3 Registered Member #97 Joined: Thu Feb 09 2006, 05:40PM
So in my physics lab we are measuring the Feigenbaum parameters using a neat little series LRC circuit where the capacitance is from a diode. If one measures the voltage across the diode the circuit follows this equation Vd+1=Vd(1-Vd)*Vin where Vin is the driving voltage. This has equation has a single stable point for low Vin, but as Vin increases the circuit goes through a period double cascade where with each cascade the number of stable points doubles until it is in chaos. Here is the write up for the lab and it does a much better job explaining than I can.
Below are some pictures I took when I tried this at home. They don't look like the ones from class and I am not sure the circuit is going chaotic, but something strange is happening.
X-Y mode where y is the voltage across the diode and X is the input voltage
1236550954 97 FT1630 Chaosxy
It is in period something (maybe)
