  • Guests: 38
Noelle (43)
King_of_Junk (36)
Ixz (35)
geobruce (31)
tulkas (32)
Gregory (31)
01/20 CT2 (37)
01/20 Josh Johnson (46)
01/21 Banana Man (41)
new railgun chrnograph idea
rp181
Sun Mar 08 2009, 05:33AM Print
Not sure if its a new idea, but i was thinking about a way to measure velocity after coming back from the science fair (which by the way, the prize money was just enough to break even with the railgun cost, with a net gain of around 2$ =p).
When the microphone is running, and the input shorted, it gives a up ward spike. When the input is disconnected, it gives a negative spike. Now what if i have rails in front of the powered rails (insulated) that connect to microphone port. When the projectile enters, it shorts, giving a upward spike. When it leaves, it gives the downward spike. Using the time between those spikes, the length of the rails, and the length of the projectile, I should be able to find speed.
Sound like it would work?
big5824
Sun Mar 08 2009, 10:45AM
getting a good connection will be very hard, you will get a lot of bounce, and it will slow the projectile i imagine. Just use light gates, much easier.
rp181
Sun Mar 08 2009, 02:46PM
I have not been able to get a lightgate to work yet, I have a break wire system setup, so ile try that.
