  • Guests: 52
  • Most ever online: 596
    Guests: 596, Members: 0 on 25 Oct : 21:25
keegan (45)
10/27 Tesla Fan (45)
10/27 Mr.Black (31)
10/27 astralhighway (11)
Microwave leak detector
G^3
Sun Mar 08 2009, 03:04AM Print
G^3 Registered Member #97 Joined: Thu Feb 09 2006, 05:40PM
I built a microwave leak detector that consists of a schottky diode in anti-parallel with an led as described on http://www.repairfaq.org/sam/micfaq.htm#micsimkleak. The only problem is it doesn't seem to work. I assume that my microwave leaks some because it is old and when I use it my wireless internet really slows down. I tried all along the door seam in various positions, but nothing seemed to work. Any hints?
Thanks
Sun Mar 08 2009, 03:19AM
The LED thing looks like a gimmick to me.
Just make a quarter-wave antenna out of stout wire, couple that to a microwave diode, followed by an op amp like OP-07 and a meter, and stick the whole thing in a diecast metal box - except the antenna, of course! cheesey
Or you could cut a stripline out of Vero board, and rectify and amplify the output of that for the meter.
G^3
Sun Mar 08 2009, 09:21PM
If I used Intensity (w/m^2)=.5*c*epsilon naught*(E)^2 where E is the electric field required to light an LED or about 1Volt/(6cm) I get an intensity of ~0.4W/m^2 or about .04mw/cm^2 and a leaky microwave is considered dangerous at 100 times that level. I guess it doesn't work, but I would like to know why.
P.S. I am using a 1n5819 and a random red LED.
Bjørn
Mon Mar 09 2009, 03:31AM
Back in the days when many of the 4HV members were experimenting with microwaves the LED/diode detector was common. If I recall correctly they used a diode that was 50-100 times faster than the 1n5819. Remember that the signal is 2.45 GHz, a medium fast or fast diode will be too slow.
Wolfram
Mon Mar 09 2009, 07:05AM
Bjørn wrote ...
Back in the days when many of the 4HV members were experimenting with microwaves the LED/diode detrector was common. If I recall correctly they used a diode that was 50-100 times faster than the 1n5819. Remember that the signal is 2.45 GHz, a medium fast or fast diode will be too slow.
Spot on. If I'm not mistaken, the diode most commonly used was the 1N5711 Link2 .
A.M.
Mon Feb 22 2010, 07:46PM
G^3 wrote ...
... I assume that my microwave leaks some because it is old and when I use it my wireless internet really slows down. I tried all along the door seam in various positions, but nothing seemed to work. Any hints?
Is it common for wireless routers to suffer interference from microwave ovens, even when the latter are in compliance with leakage standards? My guess is yes, I think Netgear WGR614v4 (for example) depends on unlicensed radio communication in the 2450 MHz ISM band. Just found a discussion here: Link2
My dad's tenant complained that his built-in MWO has been interfering with his wireless Internet connection, and with a digital electronic scale on the kitchen counter. I dusted off my old Holaday survey meter Link2 Verified it qualitatively by jamming paper behind the door of MWO at home to induce leakage. Took the meter to tenants house this morning. Confirmed the interference, and found that it went down when the MWO door was pressed just right. But the meter showed no measurable leakage, even on its most sensitive range (FSR = 2 mW/cm^2).
I told the tenant there was no safety hazard even for his wife & baby -- that I would have no problem sleeping next to the MWO -- and that I would look into the interference thing. Any ideas, other than f***ing with the door hinge adjustment and hoping not to make things worse? The wireless router is at the far end of house, and the troubled computer location is in kitchen about 8 feet away from the MWO.
[edit] p.s. Initially, the "robust 1mA meter movement" in the Holaday instrument was not moving freely. It got draggy in the bottom 20% of the range, with no visible mechanical interference. After taking it apart to the point of seeing both front and rear bearings, and looking for a dust fiber stuck in the gap, I found the probem with the aid of a 10x loupe. A splinter of ferrous metal about 1/2 mm long (.020") was stuck to the edge of moving coil. In the magnetic field it kept a radial orientation, and could not be dislodged with duster spray or a thin stiff wire. Eventually I brushed it away (?) by passing a narrow strip of paper through the gap.
Tue Feb 23 2010, 08:55AM
Perhaps the rectifier diode is working partly in varactor mode, rich in harmonics.
radiotech
Tue Feb 23 2010, 07:17PM
My diode was 1N21. It comes in a neat ceramic package and was in old radars. Narda used to furnish them wrapped in lead foil. The probes in my Narda 8700 uses thermocouples, which is why one shouldn't drop the probe. Only one way to learn this. ref Narda test set manual.
1266952640 2463 FT65254 Scan0024
G^3
Fri Oct 15 2010, 06:19AM
I bought some 1n5711's and made a simple detector and it worked. I have a new microwave and to light the LED I had to wedge a plastic bag folded over a few times into the door.
Strangely the LED on my detector fried and is now an open circuit.
Adam Munich
Fri Oct 15 2010, 07:18AM
I've used an AM radio to detect microwave leaks before. Tune it to an empty place on the band and put on some earphones. Turn up the volume as high as it goes and fire up the microwave. If you hear a 60hz hum it's leaky.
If it fried the LED then that's quite a leaky oven.
