  • Guests: 48
Sanchez (36)
Knarvel (13)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
Night Vision HUD
Zonalklism
Mon Mar 02 2009, 02:38PM Print
Zonalklism Registered Member #213 Joined: Sun Feb 19 2006, 05:48PM
I recently watched kipkay's night vision camcorder hack, and decided I could do better. However, I have run into a bit of a road block. I have the viewfinder taken off of an old mini vhs camcorder, but I need some help figuring out how to get video input into it. I would prefer a simple S-Video input solution, but any help would do. I have included some pictures to illustrate what I am talking about.
3322790094 19901faf93
The entire thing.
3321958725 34c4426426
The power connector between the lcd and viewfinder circuit board.
3322790558 D1bc756c6e
The cable connecting the viewfinder to the camcorder.
3322790804 287f30e61b
The torn down camcorder.
3322791156 0b706c2ee1
The socket on the main board where the viewfinder hooks in. (disregard the solder sticking off of it)
[Edit: Image size]
Mon Mar 02 2009, 07:00PM
Well, first off I would look at the ICs to see which one controls the LCD. With a datasheet you should then be able to see what kind of communication is used between the camcorder and display, and where you can inject a video signal.
Zonalklism
Mon Mar 02 2009, 10:47PM
Ok, an update. Uzzors, your suggestion pointed me in the right direction. With the good ole trial-and-error-and-hope-nothing-breaks-in-the- process approach, I traced leads every which way until I finally got the output from my digital camera (S-Video) to appear in the view finder. Now the only thing left is to figure out the power hookup for it. Where it hooks in to the main board on the camcorder, I can find voltages ranging from 4.5-18v with respect to ground. Will I have to supply all these individual voltages to get it to work, or will I be able to find a simpler power solution?
A side note of interest: The backlight for the lcd is an opaque rectangle that has HV leads. I'm not sure of the actual voltage, but it is enough to notice an (extremely) small arc to one's finger. Is this a normal setup for backlights? (I've gone through quite a few CRT displays, but this is my first LCD.)
Fraggle
Tue Mar 03 2009, 01:37AM
Fraggle Registered Member #1526 Joined: Mon Jun 09 2008, 12:56AM
Yes, they use (used?) cool tiny little fluorescent tubes to get the diffuse light necessary for backlighting. I`ve got one from a gameboy light.
edit: but that sounds like one of those electroluminescent panels :D
Tue Mar 03 2009, 05:00AM
You probably will need to supply a 18v and maybe 5v to it. Try clipping leads one at a time and see how few you can take it down to and have it work. Hopefully that will get you down to just a few lines, and from there you can splice in an ammeter to measure the current, and for the ones that are less than a few ma you can use a resistive divider off of the 18v signal to keep it happy. For the higher current ones you will probably want to get a lm317 (you can get them in a tiny to-93 package for work like this)
good luck!
Zonalklism
Tue Mar 03 2009, 11:09PM
Thanks for the 18v suggestion. That got the backlight working. I assume that the remaining 5v powers the lcd?
Wed Mar 04 2009, 12:25AM
That would be my best guess, but it could be any weird voltage the designer decided to use.
Zonalklism
Wed Mar 04 2009, 12:44PM
Haha, that's true. Man, if I was employed to design circuits for some company, I would love to mess with people like us. *some guy taking a camcorder apart* - "What the flux?! Why does this thing convert 120v AC into 12v DC, back to 120 AC, then to 1200v, then back to the 12v needed to run the viewfinder? IT DOESN'T MAKE SENSE!"
