  • Guests: 55
Sanchez (36)
Knarvel (13)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
IP Core Material Selection
KLH
Mon Feb 23 2009, 08:37PM Print
After looking at the specs for the #26 iron powder material from Amidon and other people's remarks on this material, I was wondering if another material could be used with better DC saturation characteristics, lower loss, and lower permeability. The material I was thinking of using is Amidon's #2 material, with a permeability of 10. My question: Would a lower permeability result in a higher magnetization current / energy, and therefore lead to more losses? The core will be used for a high power inductor.
Thanks in advance for any help.
Mon Feb 23 2009, 09:24PM
There is no 'standard' answer..depends upon the application.
What are;
- desired inductance
- at what average dc current
- ac voltage ripple
- at what frequency
- cooling arrangements (forced-air etc.)
Specifically #26 is good for common-mode rfi filtering
it's not good with 100's of kHz even.
#2 is commonly used for transformers and inductors in amateur HF designs,
due to volume of use it's actually relatively available and cheap.
For hobby use where size isn't the main concern, I'd use #2 rather than #26,
I use #61 = 4C65 quite a lot, so far so good.
I sometimes use MPP cores which are great BUT too expensive.
Gapped ferrite is good to 100's of kHz..potentially many MHz.
For any material you're considering, as a quick guide
look at the graph that shows Us' and Us'' vs. frequency,
Us' is inductive, Us'' is resistive. Where the two cross Q=1
For an inductor I generally aim for Q>>10.
Ultimately design comes down to ensuring average core dissipation is
<100mW/cm3 for large cores and <200 mW/cm3 for small cores.
If my memory is still error-free ;)
GeordieBoy
Mon Feb 23 2009, 09:57PM
The optimum grade of iron-powder depends on the application and specifically the required inductance and DC bias conditions it will be subject to.
#52 material (Green/Blue) is a low loss version of the cheap and common type 26 material often found in light dimmers and PC power supplies. In many applications it is a drop-in replacement and will run cooler due to the lower core losses.
Type 2 is good for things like RF power transformers and Radio Frequency Chokes. The carbonyl iron powder is low loss, and has excellent resistance to saturation due to heavy DC bias. The downside is that the permeability is lower so you will need more turns to get the same inductance value. This may mean that copper losses are higher.
Materials like #34 and #35 are somewhere in between. They have a medium permeability and reasonably low core loss. They are often used for things like boost PFC chokes where input ripple is typically quite large. In such applications type 26 would overheat due to excessive core loss, and type 2 would overheat due to excessive loss in the copper windings.
Micrometals website has a good bit of design software on there which lets you compare the designs of magnetic components using different materials and core sizes.
-Richie,
KLH
Tue Feb 24 2009, 07:58PM
Thanks for the advice, I was wondering what the green-blue material was. But I still have a couple of questions...
Sulaiman wrote ...
What are;
- ac voltage ripple
- at what frequency
My inductor is 50 uH ~22 Amp DC, 60 turns on a #2 material T-106 core from Amidon. This will be used as a buck inductor, where the AC ripple is relatively small (expected to be around 1A).
From what I understand, the #2 material core can be used in this inductor configuration. The reason I picked the #2 material at the start is because its permeability barely decreases at the specified DC current and core size. I calculated the DC magnetizing force to be around 264 Oersteds, resulting in an inductance drop of only ~2uH at full rated DC amps. What I'm worried about is that the lower permeability of this material will result in higher magnetization current and therefore wasted energy / loss.
If this loss is greater, would it be significant enough to exceed the core loss limit of 100mW / cm^3?
On a side note, I thought that common-mode AC line filters were made of high-permeability ferrite with a bifilar winding. In the Amidon databook, it says that the #26 material is used for differential mode AC line chokes.
GeordieBoy
Wed Feb 25 2009, 12:11AM
The only problem I see is that you won't be able to get 60 turns of wire capable of carrying 22A through the ID of a T-106 core. You will probably need to use something like a T-200 to give you enough winding window. It also depends on whether you want to make the inductor with a single layer winding or can tolerate multiple layers?
That is correct. High perm MnZn for common-mode filtering like at the input to SMPSUs. Hydrogen reduced iron-powder for low-frequency differential-mode filtering like in light dimmers.
-Richie,
PS. I'd recommend the design software on Micrometals web site. It will quickly allow you to compare the various design options for DC biased buck chokes and make an informed choice.
Wed Feb 25 2009, 12:30AM
D'oh .... Sorry, brain-fart.
#26 material is for Differential-mode rfi filtering
KLH
Wed Feb 25 2009, 02:22PM
GeordieBoy wrote ...
-Richie,
I guess I didn't think about that; 10 layers of 60 turns of 24 AWG wire is NOT going to fit.
Thanks for all the help!
GeordieBoy
Wed Feb 25 2009, 02:59PM
For your buck converter, what is your:
1. Switching frequency
2. Input voltage
3. Output voltage
4. Maximum output current (22A ?)
These are the things you need to know in order to design the output choke.
-Richie,
