  • Guests: 35
10/15 OiD (38)
10/15 jolty (50)
10/15 Baran (29)
Induction Heating
skmetal7
Sat Apr 01 2006, 07:13PM Print
skmetal7 Registered Member #101 Joined: Thu Feb 09 2006, 08:12PM
today i was just experimenting with inductoin heating. i have a zvs driver so i thought, "why not?" i heated up a 10-32 bolt to red hot in about 15-20 sec. here are some pics:
1143918436 101 FT0 Induction Heat
1143918436 101 FT0 Induction Heat02
at first i ran it off of my 5 amp variac, but it was drawing close to 5 amps at only 20 volts, so i found another transformer and now i am runnig it at about 43 volts, ill check the amps later.
quick Q: does my work coil have enough/not enough turns? i tried with less turns and the coil on the ferrite core started to melt. but this many turns seems to work ok.
Marko
Sat Apr 01 2006, 08:23PM
Nice work skmetal smile
That coil obivously melts because of overcurrent.
You connected it with work coil with aligator clips so you have large spot resistance and heat is probably coming from that spot, and part is probably conducted trough copper wire from heated target.
If it still smokes just remove insulation from it smile
By reducing number of turns you actually get lesser current flowing trough the target, because of turns ratio. Getting turns closer (but not touching) may also help.
skmetal7
Sun Apr 02 2006, 06:31PM
Ran some more tests and found out that it runs off of 430 watts at 43 volts. i tried heating up a 5/16"bolt and it took ~20-25 secs to heat to red.
1144002225 101 FT6389 Induction Heat 002
10-32 bolt:
1144002513 101 FT6389 Induction Heat 001
1144002513 101 FT6389 Induction Heat 005
1144002513 101 FT6389 Induction Heat 006
power supply:
1144002513 101 FT6389 Induction Heat 010
Dr. Shark
Mon Apr 03 2006, 09:34AM
Nice one! Are you using the ZVS circuit straigh from a flyback driver, or did you adjust the resonant capacitor for a higher frequency? For induction heating you want someting arould 200kHz, so the .68uF should probably be replaced by 100nF or so.
BTW, I like it how you managed to employ some Dremel tool parts even in this experiment!
skmetal7
Tue Apr 04 2006, 02:17AM
yep the zvs, plan in playing with the cap values a little though. each cap reads ".5 MFD" i'm guessing that means .5 micro farads... rolleyes one started to get hot so i put 2 in parallel. so its 1 micro farad. that is all i had laying around, but it works for now! i need to get some better caps, what type are preferred? Tantalum, polyester, Polypropylene? seems like my caps always get warm-hot (even when driving a flyback)
Dr. Shark
Tue Apr 04 2006, 02:44PM
OK so you are properly just heating the iron by hysteresis losses, but still not bad. Love the ZVS
For tank capacitors which see continous high RF currents people usually prefer pulse grade plastic caps. The difference is usually the thickness of the metal film, which has to support the high currents. I have had good look with some WIMA caps, but in the US you proably have different manufacturers.
