  • Guests: 103
davovinch (75)
Duncan (37)
Vatorius (60)
waicool20 (27)
12/11 Forty (38)
12/13 williamn (48)
12/13 ReddyK (57)
TEA laser help
Wed Feb 11 2009, 12:47AM Print
I have been trying to make a tea laser for a while now. I can not get the even discharge that is required for lazing. I am using a single projector sheet as the dielectric and a small deionisier as the power supply. Could the power supply be causing my problems? Thanks
EEYORE
Wed Feb 11 2009, 02:57AM
Could be a number of things, but I would suggest your electrodes as the first thing to look at. What are they? Pics?
matt
Wed Feb 11 2009, 03:07AM
Aluminum V rails, polished. I think one might have a slight bend ( >1mm)
Bjørn
Wed Feb 11 2009, 04:09AM
You probably have to straighten out the bend. Read this if you have not: Link2
Wed Feb 11 2009, 07:30PM
Done. Laser is still not working, all I get is about 5 sparks on different parts of the rails. sad Could the high voltage, low current and low wattage (>5 watts)
EEYORE
Wed Feb 11 2009, 09:05PM
If your getting sparks across the channel, it could be that your electrodes "edge" isnt smooth. I believe the edge needs to be extremely uniform. The electrodes are usually the hardest part to get right of a TEA N2 laser. I dont think the high voltage section is bad if its arcing...
Matt
hboy007
Fri Apr 03 2009, 04:02PM
The electrodes need to be plain aluminium, non-eloxated. If your Laser doesn't work, this may have several reasons:
the discharge edges are not perfectly straight and well-aligned (you know what to do)
peak voltage is too low (widen the spark gap)
inductance is too high (reduce parasitic inductance loops)
now show us some pictures, will you ;)
ps. damn, didn't see this is an old thread :(
Fri Apr 03 2009, 05:28PM
piece of copperclad with groove hacksawed in as a top electrode :)
might be worth a try, don't know about long term use though..
just a thought but it might be amusing to build an array of them on a circular piece of board with their own power sources, to generate high peak power at the centre.
EDIT:- doesen't work, the discharge channel needs to be absolutely smooth. i tried NIB magnets end to end but this also failed (probably due to the opposite electrode)
