  • Guests: 29
Sanchez (36)
Knarvel (13)
10/16 Sanchez (36)
10/16 Knarvel (13)
Death by Capacitor vs. Lightning
cduma
Mon Feb 09 2009, 01:00AM Print
Why Is the survival rate for Lightning strike victims higher than those who get hit by a high voltage capacitor. Lets call high voltage 10kv. Why do capacitor victims not require immediate Kidney Dialisys machine to survive more than a day or two but, lightning victims do.
Backyard Skunkworks
Mon Feb 09 2009, 01:57AM
I'm not quite sure what your talking about, but I should point that getting hit by lightning IS getting shocked by a high voltage capacitor. I'm also not quite sure where your getting your stats from, although I do remember that something like 75% of people who get hit by lightning do survive. And someone correct me if I'm wrong, but I don't think there is anything special about getting hit by lightning that requires kidney dialysis.
Chris Russell
Mon Feb 09 2009, 02:21AM
Chris Russell ... not Russel!
A quick Googling around indicates that lightning strike victims can suffer from myoglobulinuria, presumably due to rhabdomyolysis -- damage to muscle tissue. All the good articles about this are behind various paywalls, but from what I can gather, it works like this: If a lightning strike does massive damage to the muscles, myoglobulin is released into the bloodstream in large amounts by the damaged tissue. This can cause kidney failure if left untreated, as the kidneys can only handle so much myoglobulin at once. It's not unique to lightning strikes; any sufficiently large amount of trauma can cause this condition. I see no reason why a large capacitor shock, or any sufficiently powerful shock, couldn't cause myoglobulinuria.
As to the higher survival rates, I'd guess that the shorter lightning pulse leads to increased skin effect, meaning lethal currents are less likely to reach the heart as compared to a capacitor hit, which has a much much longer pulse time in most cases.
LithiumLord
Mon Feb 09 2009, 02:31AM
LithiumLord Registered Member #1739 Joined: Fri Oct 03 2008, 10:05AM
As far as many refer the step voltage shock, the shockwave effect and getting shocked by a leader or just the static charge induced by a huge dv/dt as a lightning strike I see the reason why ;) Otherwise, if considering "getting hit by a lightning" an actual headshot, I bet there's not much chance to survive, at least not higher then the one of one's corpse to remain in an "SFW-pic-friendly" condition that is really slim to nothing ;)
Mon Feb 09 2009, 03:24AM
Shocks from 240V or higher you should go to the hospital as soon as possible. In trade school they drill it into our heads over and over, the reason being that a shock from 240 or higher can cause the blood in you to burn a little forming a clot that can grow and lodge some where important killing you hours later. That may be one of the reasons why you have to be put on a dialysis machine to remove any burned bits from you.
As for why lightning hits seem to be more survivable then a capacitor shock, could be the path both shocks take and the duration. In a capacitor it will probably be from your hand to your other hand or another limb and lasts a significant amount of time if it is a big enough capacitor at a "low" 1-2kv voltage. Lightning on the other hand will be going head to toes lasting (wikipedia) ~30uS, perhaps having the current spread across your whole body cross section instead of between two limbs help stop the much higher current from killing you.
LithiumLord
Mon Feb 09 2009, 10:42AM
Well, this is getting a bit of paranoic, don't you think? ;) In fact you are mixing the two different effects - getting "hit", when the shock just makes the screaming you jump aside and land flat on your back, and getting "attracted", when the muscular shock makes you unwillingly hold the object under voltage with a strong grasp. The first effect has merely any lasting consequences as the exposure times are usually very short to cause such a high heating of the tissues and liquids (speaking of the voltages below ~500vac - as voltages referred as "high", eg. 1+Kv, are those that definitely cause some lasting effects, including burns, neural damage and blood damage). Getting "attracted", as some people call it, is another thing - the exposure times are high enough to cause the thermal damage as well as the neural one and a bad hit on the muscular tissue. However don't forget that RF currents, like those of Tesla coils, have pretty the same effects - even if you can't feel the hit itself.
As for the lightning, only the energy counts - and it is enough no matter what part of a man's volume it needs to heat up. Even the shockwave itself is enough to crack a cinder block in two (a guy who worked with the lightning protection test system once told me how someone left a cookie on the test platform. When the system was a press of a button from being engaged, an unlucky crow came down for it's breakfast, guess what happened. With a man it will not do such a painting job, but I bet there's not much chance to live through that). Actually, this discussion feels pointless unless we have a straight statistic on those hit with caps' charge (those exposed vs those who survived/died at the specific cap bank energy) and same for the lightning hits (head-on hit, same two values). Or it may get funny the other way - one man ended up drilling a hammer drill up his forhead to travel half of his skull - and lived. Doesn't this mean that it's 100% safe to drill your head with a hammer drill? ;)
PS Link2
If you'll take a closer look, NONE of those here had a direct hit ;) (only leaders and step charge hits)
Shaun
Mon Feb 09 2009, 05:27PM
LithiumLord wrote ...
PS Link2
You could always get lucky and wind up with ESP, like "Missy".
big5824
Mon Feb 09 2009, 06:12PM
just out of interest, does anybody know how much capacitance an average storm cloud has?
Also, I thought the kidney dialysis was because the DC shock can electrolyse some bodily fluids, releasing harmful chemicals.
Mon Feb 09 2009, 07:20PM
Wasn't aware of this side effect...
That said, I know of someone who was struck by lightning, and they didn't mention anything about dialysis. maybe it only occurs a percentage of the time.
-A
Bored Chemist
Mon Feb 09 2009, 09:27PM
If your capacitor stored something like 100MJ to 500MJ at 10KV it would do much the same to you as a thunderbolt.
