  • Guests: 32
Sanchez (36)
Knarvel (13)
10/16 Sanchez (36)
10/16 Knarvel (13)
lightning strikes
Fri Feb 06 2009, 03:03AM Print
I've asked this before, but I'm hoping there are others with some field experience that can offer their opinion. I am looking at the DELTA 303 3 phase lightning arrestor.
How effective are these at protecting electronic equipment from a *direct* lightning strike. My guess in not that effective.
This begs another question. How do utility companies protect their high voltage transmission lines from lightning strikes? Surely, lightning rods can't work all the time?
Tom540
Fri Feb 06 2009, 06:33AM
Tom540 Banned on 3/17/2009.
I think they have giant MOV's attached somewhere or something similar.
ConKbot of Doom
Fri Feb 06 2009, 12:17PM
The main issue with a direct strike, is your sending multiple KA down the line, and even if the arrestor works as it is supposed to, the enormous current in the wiring can induce current and high voltages in nearby electronics.
I recall seeing one story where a church had an old lightning rod, ground wasnt the best on it and lightning hit it one time, arced from the ground wire to an old natual gas line for gas lanterns (no gas in it, it was out of service) but the gas line looped around the sanctuary, and the field setup blew out most the audio equipment and lighting.
By all means put the arrestor in, it may be capable of arresting surges in the power caused by near strikes, and if it saves some equipment even once, it'll probably be worth it.
Fri Feb 06 2009, 02:44PM
I once tested a 3P+N surge arrestor in a control panel for a machine by accident, I switched phase 1 and neutral on the main breaker, (stupid french shit puts N terminal in the opposit side of others), but I did not double check it :)
Well, the arrestor worked fine, it was a nice and red unit, and afterwards it was black, blown out but nothing else got damaged.
GeordieBoy
Fri Feb 06 2009, 04:45PM
Spark gaps formed between large metal arcing horns. These can carry lots of current! wink
-Richie,
Fri Feb 06 2009, 09:23PM
Dennis Rogers Registered Member #1837 Joined: Tue Dec 02 2008, 02:20PM
I saw a special about high voltage transmission lines on the history channel the other day. Many have unshielded wires on the highest point of every tower. These lines protect the current carrying lines below them.. (or so the theory goes). The linemen who work on them say they work well. So well that if there is the threat of lightning within a few miles they halt work because the lightning can go miles on those top conductors before it is shunted to ground.
