  • Guests: 30
Sanchez (36)
Knarvel (13)
10/16 Sanchez (36)
10/16 Knarvel (13)
Capacitor current
ebp
Thu Feb 05 2009, 02:42PM Print
ebp Registered Member #1933 Joined: Sat Jan 24 2009, 10:53PM
Hi does anybody know how determine the current of a capacitor? It's easy to determine the energy stored but I need how long a discharge takes to calculate the current. My capacitor has these specifications:
Sprague
748d
din 41248 gpf
250V
2200 microfarad.
Thu Feb 05 2009, 03:11PM
This is the only aluminum electrolytic capacitor from sprauge at 2200uF / 250V I could find, you can use the ESR values from the datasheet to calculate you discharge time through whatever load you might have in mind.
datasheet: Link2
math that might be useful:
A little google quality time and you could have found this by yourself, but here it something for you to read :)
cduma
Sat Feb 07 2009, 09:07PM
This depends on the load almost entirely especially if it has a decent amount of resistance. You need to know the RC time constant. R*C= Time in seconds it take to reach 63% of the original or supplied voltage.
Bored Chemist
Sun Feb 08 2009, 09:39AM
If the cap is discharged into an inductor and the resistances in the circuit are small, the peak current can be calculated from 1/2 I^2L = 1/2 V^2 C
In any event, this will be the maximum current you can get.
