  • Guests: 29
Terrorhertz (16)
10/01 Avalanche (42)
10/02 Carl A. Willis (45)
10/03 TwirlyWhirly555 (33)
ne555 sine wave ?
Duality
Mon Feb 02 2009, 05:12PM Print
Duality Registered Member #1951 Joined: Sun Feb 01 2009, 01:59PM
is it possible to make a sinewave generator with a ne555,
can't seem to find it? (on the net)
(i have a stupid comp anny way)
anny way i just want to know if it's possible ;)
Mon Feb 02 2009, 05:22PM
Yes and no. It is possible to make something pretty close to a sine wave.
Since you can't achieve a perfect 50% duty cycle with a 555, you can't achieve a perfect sine wave. However, by getting as close as possible to 50%, and filtering the output with a couple of chebychev or similar low-pass op amp filters, you get something pretty darn close to sine wave.
This works because a square wave is basically a number of sine waves (the fundamental frequency plus its harmonics) all wrapped together. By filtering out the harmonics, you're left with the single sine wave at the fundamental frequency.
Dave
Mon Feb 02 2009, 06:22PM
Dave Marshall wrote ...
Well if you were going to use a "couple of" op-amps, you can as well make a sine wave oscillator with just a single op amp. And it will be a nearly perfect sine wave. Link2
KLH
Mon Feb 02 2009, 06:55PM
Dave
It is possible to achieve an exactly 50% duty cycle with the 555; just put a diode (1N914 or similar) with cathode to pin 2 and anode to pin 7. Making the 2 resistor values equal gives a duty cycle of very close to 50% (varies with resistor tolerance, so I recommend using Xicon's 271-XX-RC 1% metal film resistor series).
You can then use a capacitor-based low pass filter, but an LC filter will be much more effective at eliminating harmonics.
But as Dr. Kilovolt said, it's better to make an op-amp based sine wave oscillator. However, I prefer the phase shift oscillator (it's on Wikipedia) because I think it's simpler and easier to get working. It requires only an op-amp and a handful of passives.
Duality
Mon Feb 02 2009, 07:06PM
really thanks for replying ;P
i asked because i have toooooo much ne555's laying around XD
i have two high-speed comparator's can't i use them instead, or do it need to be op-amps?
if so are the lm386 good for this?
Bored Chemist
Mon Feb 02 2009, 07:41PM
If you run two 555 square waves with similar frequebncies into a comparator then low pass filter the output you get a sine wave with a frequency equal to the difference in frequency between the two 555s. The heterodyne oscilator or beat frequency generator. This is usually a daft way to generate a sinewave- unless you happen to have lots of 555s and lots of comparators
Duality
Mon Feb 02 2009, 07:44PM
ne555's enough comparators not :(
Mon Feb 02 2009, 07:51PM
Bored Chemist wrote ...
I would think that would generate a triangle wave confused
Bored Chemist
Mon Feb 02 2009, 09:02PM
You might be right, what about adding the 2 square waves?
Tue Feb 03 2009, 10:25AM
The "industry standard" way of doing this is to use switched current sources to make the 555 generate a triangle wave on its timing capacitor, instead of the usual exponential sawtooth. An overdriven transistor long-tailed pair is then used to "soft clip" the triangle wave into a sine wave.
This is mathematically exact, because the transfer function of a long-tailed pair is tanh something or other. In practice you can make it work with about 1% distortion. It works over a very wide frequency range without adjustment, unlike all of the proposed schemes here using filters.
It's also how the sinewave output works on function generator chips like the ICL8038 and MAX038.
