  • Guests: 26
Ben7 (29)
12/18 Skywarrior (52)
12/18 Dark Horse (54)
12/18 LD LANGER (38)
UV light from HV arcs?
Franky
Thu Jan 29 2009, 03:18PM Print
Franky Registered Member #1940 Joined: Tue Jan 27 2009, 02:34PM
When I showed somebody my plasma speaker, he warned me about the UV light that is produced inside the arc. UV light can damage your eyes.
Is this true? Is the UV light, which comes from the arc, strong enough to do damage to your eyes?
I’m talking about a small plasma speaker like this (arc length max 5 cm).
446580531 6 DMIp
446580583 5 CkP6
At the moment I’m using some glass to protect my eyes.
Thu Jan 29 2009, 03:42PM
Thu Jan 29 2009, 03:48PM
The low power arc (<0.2A) from a TV transformer doesn't produce much UV. I have played a lot with flyback arcs, also with powerful 2amp MOT arcs (here I recommend using sunglasses), and my eyes are fine.
The tesla coil gap is a different story, peak currents of several kiloamps do indeed produce a ton of UV.
Coherent
Thu Jan 29 2009, 07:02PM
Coherent Registered Member #1886 Joined: Sun Dec 28 2008, 02:55AM
IMO if the arc is too bright to look at comfortably(High current MOT arcs/welding arcs/spark gaps/capacitor discharges) then wear sunglasses or don't look at the arc.
NST's and Flybacks don't produce much hard UV from the arc and are usually safe to look at. If you're really concerned then put a glass shield around your plasma speaker arc.
Thu Jan 29 2009, 08:55PM
I have produced large amounts of even low current sources (ie, ccfl driver). The easiest way to tell how much uv you are making is to take a piece of white printer paper and hold it up next to the spark, if it glows blue then you have a considerable amount of UV light being produced.
BTW, the purple glow you see in your camera is IR radiation leaking through the color filter, cameras do not respond to UV well and what they do see shows up as blue.
Cheers
