  • Guests: 38
Skywarrior (52)
Dark Horse (54)
LD LANGER (38)
12/19 kywalda (63)
12/20 plazmatron (48)
12/20 rm203tech (17)
Need help with Van der Graaf
Dieu
Sun Jan 25 2009, 12:03PM Print
Dieu Registered Member #1730 Joined: Thu Oct 02 2008, 08:12AM
I have some questions about this constustion, but first is most important:
Are brushes need to be connected to belt? Or it's is abspluty prohibit?
Soon it will be ready to run.
DerSchwamm
Sun Jan 25 2009, 12:22PM
DerSchwamm Registered Member #1936 Joined: Sun Jan 25 2009, 11:34AM
As far as I remember (I haven't built one myself) the brushes don't actually touch the belt, the electrons "jump" off the belt onto them.
Are you building a traditional van de graaf generator (nothing powered besides the motor to turn the belt) or an E-fieled triboelectric generator where you're spraying the belt with electrons from a HV source?
Dieu
Sun Jan 25 2009, 03:05PM
Secound one.
It's really easy projest, but unpopular.
I'm not shure, but maybe belt needs olny to be polarized by HV, but I'm not shure.
Antonio
Sun Jan 25 2009, 04:22PM
The usual is to use metal combs close to the belt, but not touching it. Light brushes touching the belt work too. I have a VDG using brushes taken from the output slot of a discarded laser printer.
ToddA
Thu Jan 29 2009, 09:05PM
ToddA Registered Member #1943 Joined: Wed Jan 28 2009, 08:39PM
The brushes, or combs as they are called do not touch the belt but are as close as possible. They should also be thin wire or needles soldered to a circuit board. Self excited VDGs have the upper and lower rollers made from materials at either end of the Triboelectric series. For example, on mine I have a PVC upper roller and a Nylon lower roller. PVC is at the negative end of the series and Nylon at the Positive end thus the output is Negative. When injecting a voltage just be sure that the roller materials are opposite the polarity of the input voltage to obtain the best output.
Hope this helps!
Todd
Antonio
Thu Jan 29 2009, 11:35PM
I like to make combs with aluminum foil cut to form points. Avoids the risk of scratching the belt on an accidental contact. I use rollers made of Teflon and Nylon. Nylon is too conductive to become significantly electrized, I could use metal instead, but Teflon is excellent for electrization in contact with latex.
Raka
Sat Jan 31 2009, 12:01AM
Raka Registered Member #1838 Joined: Tue Dec 02 2008, 06:01PM
I used the flat data cables found in old computer for the brushes. Just strip the last 2mm of each wire the other end is soldered together. Worked like a charm
