  • Guests: 67
01/04 bomberguy92 (34)
01/05 Timo (40)
01/06 Ash Small (63)
Are these caps any good?
Coherent
Mon Jan 26 2009, 08:10PM Print
Coherent Registered Member #1886 Joined: Sun Dec 28 2008, 02:55AM
I found these big caps on ebay and I'm wondering if they're worth the money. Would they be good for pulse discharges? A lot of caps on ebay are listed as good pulse/tc caps when they actually aren't.
Mon Jan 26 2009, 08:28PM
Only two of them seems to come in a insulated casing, bushings seems thick enough, but could still be PFC caps.
But I do not know about chemical capacitors.
Lakeowner
Mon Jan 26 2009, 09:10PM
Lakeowner Registered Member #1370 Joined: Mon Mar 03 2008, 09:01AM
"Very old" and General Electric leads to PCB's if they use any oil. I wouldn't buy anything but polypropylene caps for TC usage. You can imagine a boiling capacitor splashing PCB oils everywhere while you run for your live and scream NOOOO.
Coherent
Mon Jan 26 2009, 09:26PM
Would they be any good for blowing stuff up?
.02 µF at 28KV doesn't seem like that much energy. How many joules is that?
El_Roberto
Tue Jan 27 2009, 04:32AM
El_Roberto Registered Member #1774 Joined: Wed Oct 22 2008, 02:51AM
7.84J, It wouldnt be very good.
Coherent
Tue Jan 27 2009, 05:40AM
I guess these aren't worth it then. Thanks for the advice.
Fraggle
Tue Jan 27 2009, 11:17AM
Fraggle Registered Member #1526 Joined: Mon Jun 09 2008, 12:56AM
Laakkonen wrote ...
Lol, most articulate - I can almost see it now :D
Tue Jan 27 2009, 11:53AM
Did anyone notice that they have an "800 pps" rating?
PPS is pulses per second, and it suggests they were used in a pulsed power application, like a radar PFN or whatever. So, might be worth a try in a Tesla coil, although that's more stressful than a radar application, where they may not see any voltage reversal.
Bamacoiler
Wed Jan 28 2009, 05:14PM
Bamacoiler Registered Member #1628 Joined: Wed Aug 06 2008, 08:48PM
I bought 4 of them for my big coil I'm building. Same capacitor bank used in the Warthog coil. Google Warthog tesla coil. Look like dang good caps to me for the price.
Wed Jan 28 2009, 05:49PM
I personally wouldn't use them for the following reasons:
1. Old
2. Oil based (PCB likely) Capacitors
3. Old-Oil based means they likely have dielectric that has dried up leaving less than desirable capacitors
4. Pretty shoddy / rusty looking - Another sign to be wary of these capacitors. If they were very new looking, then they might be okay, but not in the condition as advertised.
5. Big bushings, despite the spec rating, imply a filter type capacitor - not a heavy discharge capacitor. The typical application for this type of capacitor is for filtering high voltage in tube based radar transmitters. Basically, used to filter the ripple (droop) on a cathode, or depressed collector, etc... Not for repetive discharge of the type of large TC would see. True pulse discharge capacitors have no bushings.
My recommendation: PASS
Plus, they're expensive too for what they are.
