  • Guests: 22
EEYORE (42)
TeslaJunky (32)
07/16 Gavin (49)
07/16 Froskoy (33)
07/16 UnHappy1 (59)
ZVS Light Inverter
MRacerxdl
Fri Jan 16 2009, 03:14AM Print
Hi all, today I build my ZVS Light Inverter, for fluorescente lights and CFL LCD Backlight too.
Its a common zvs with two STD20NF20 Mosfets (200V 20A 0,1Ohm SMD) running at 12V, 1uF cap.
Tomorrow I will finish my transformer for work with this ZVS, I tested today with a common flyback and works very fine without much more than a little heat at mosfets.
Here are a pic from the board:
Tomorrow I post a few more pics and specs :D
Myke
Fri Jan 16 2009, 03:22AM
Cool. smile
How much current does it source (or what series resistance are you going to use)? You don't want to burn up the electrodes of the lamp.
Firnagzen
Fri Jan 16 2009, 08:52AM
Firnagzen Registered Member #567 Joined: Tue Mar 06 2007, 10:55AM
EH. Just one thing, those aren't SMD FETs, they're IPak.
