  • Guests: 51
11/29 Sonic (59)
11/29 kamelryttarn (47)
11/30 arnsfelt (46)
first coilgun
phinsil6
Tue Jan 13 2009, 09:11PM Print
phinsil6 Registered Member #1914 Joined: Wed Jan 07 2009, 06:50PM
i am attempting to make my first coilgun. i have made successful low power solenoids in the past but never a coil gun. Here's the plan. I am going to make this boost converter
to get 24DVDC to 450VDC to charge up a bank of 500V 1500uF capacitors. I plan on using 14awg square magnet wire on a 4" pvc pipe. does all this sound right? please advise on any problems. also, some help on how this schematic works would be great as well. i have the general idea down, and all the parts on their way, but i have to admit, the actual schematic is quite daunting. thanks for all comments and advice
rp181
Tue Jan 13 2009, 09:38PM
Every thing will for fine, excepts the 4" pipe. 4" pipe is way to big, use 1/2" or smaller.
phinsil6
Tue Jan 13 2009, 09:45PM
how many layers should i put on this 1/2" pipe, because that's not very long at all. in fact that seems really short, all of the other powerful guns i've seen have been longer coils than that
rp181
Tue Jan 13 2009, 10:58PM
Oh sorry, i thought you meant 4" PVC, as in diameter. For length 4 inches is fine. What bore size are you doing? How long is your projectile?
KLH
Wed Jan 14 2009, 06:15PM
What is your total energy storage? (Energy = 1/2 * Cap Voltage * Capacitance in Farads) In addition, how many urns / layers are you going to use for your coil? The reason why I ask is that 14AWG just may be too small, depending on its inductance and how much energy you dump into it. My 96-turn 10AWG (!!!) currently dissipates over 50% of the input energy, with a peak current of 6150A and an input energy of 1903.5J.
Thu Jan 15 2009, 06:33PM
Correction, use the voltage squared, as in:
Potential energy PE = 1/2 C V^2
where C is capacitance in Farads, V is voltage, and energy is Joules
